Should the next lift be more intricate (involving replacement parts) and expensive?
  • Yes, we'll pay more ($500 - $1000) 3" lift that increases travel/articulation by adding more parts.
    Votes: 23 62%
  • No, we'd like a direct competitor to RRO.
    Votes: 14 38%
To Daystar, RockKrawler, ARB:the next lift
5.1K views 30 replies 11 participants last post by  JeepJim
I was thinking, a lot of us have been contacting guys like RockKrawler, Daystar, and even ARB in hopes of convincing them to create a new lift kit.
My feelings are this: whoever creates the next kit has to do more than a spacer lift. Seriously.
RRO already has a spacer lift available, and the price is pretty cheap. What is the sense of another one? How much could they possibly beat RRO by....$50?
Lets face it, everyone is tickled pink that RRO gave us some attention, but there are some of us who are looking for more. It only makes sense that the next lift should be one that requires some replacement parts in order to increase things like suspension travel and articulation, and to bypass the current limit of 2.5" of lift.
Maybe this costs the consumer close to $1000.00. I'd pay it. Anybody else or would the majority of you be happy to see the next lift turn out to be a "me too" spacer lift that is more or less the same as RRO's kit?
You have to remember...there is only so far you can allow teh wheels to drop below the level of the transaxle or you will exceed the ange at which the CV joints work properly. You will get driveline binding and all kinds of problems. So i feel that to get a lift that tall you would have to allow teh motor t osit lower in teh engine compartment. I believe the transverse engine design may have limited us to less than 3" of lift.
Wouldn't new parts fix this? If someone basically re-engineered the suspension, similar to the way they do for the Wrangler, would it be possible to get 3"?
Also, could you explain how the transverse engine limits the Patriot. I don't understand what transverse engine means....in truth, I like to dream up inventions, but I have no idea what goes into them.:D
I would voted yes. I think it would be great to see a three to four inch (preferably a four inch) lift kit that relocated the suspension mount points to completely correct the geometry, kept the drive shafts at safe angles as well as added some additional suspension travel.
One reason I say this is after parking my 'Riot (which is lifted) next to a non-lifted 'Riot (both are FDI) I was a little disappointed in how mine looked. It really wasn't that much taller at the roof line. Yeah you can tell at the wheel wells and if you paid attention to the tire size. But at the roof line, not so much.
The problem isn't driveshafts, it's axleshafts. The angle of the CV joints would become too large, leading to binding and failure. It's the same with most IFS vehicles. However, vehicles with non-horizontally opposed engines (like fullsize trucks, etc) can remount the front diff at a lower location, making the cv angles lower. Transverse engines with a transaxle would require the entire engine/transaxle combination to be dropped, or extensive work be done to accommodate a spacer between the engine and transaxle. With that said, I have not looked closely at the Patriot drivetrain, so I do not know for sure if there is a separate front differential, or if it is built into a transaxle.
sorry to be a bummer on the intent of the thread, but I'm happy with the RRO style lift being offered by one company. Keep in mind also that manufacturing costs go down with volume, so the more lifts RRO sells, the less expensive they should get. By splitting the number of body (i.e. RRO style) lift kits sold between two or more companies won't help.
I'd be happy if RRO still sells the lift when I'm ready to buy it, and that it's been improved with the learning they do each time they manufacture it.
I need another option to vote on the poll.
I'm happy with a 2" lift on top of my FDII. I think get me way more than enough clearance and tire size for the rough logging roads I drive (but I still need to prove that my stock FDII is enough once the damned snow melts).
Agreed. Polish's point is good. However, I'll counter and say that without some competition, the RRO lift has no incentive to ever improve the product they sell.
I find it funny that RRO offers more indepth kits for the Liberty, but not for the Patriot. There are several options for the Liberty, starting from a budget lift and eventually ending with the Rockfather II. The price range is from $214 - $809.
Obviously the Liberty has been out longer than the Patriot....but the point is: What pushed them to offer more than one lift? Perhaps it is because Daystar, and Frankenlift, etc all came out with lifts and added items like new shocks, etc.
RRO is better than nothing. The next step is something better than RRO. Otherwise, we are moving horizontally. I prefer progress.
the short form is heckler please. :) heckler was taken when signed up here and on E-bay. My bike (a heckler) also happens to be polished aluminum.
My biggest issue with a 2" lift is that by the time you add rails under the plastic rocker trim, you lose the lift! I would love a 4" lift (no matter the cost) with rails that replace the plastic trim and encase the seam weld. Been trying to get people to build such rails, but it's tough to find someone with the time.
Dawson,
Not to start a new topic (though we probably could in "Exterior"), but since you mentioned it, what is behind/underneath the plastic side trim? Can you pop it off? Although it isn't the lowest point, I'm sure you lose a lot of "wheel over obstacle" ability with that thing.
For example, my Blazer measures 14" from the ground to the side trim...but ground clearance is only like 7.9".
ya know. we ALL could get a bigger lift with the RRO kit 'if' it had, instead of a front strut spacer, a new front strut that would be longer from the spring guard to the point where the knuckle mounts. if they added the 2+" THERE instead of using the spacers, then the only thing keeping us from using TALLER TIRES would be modifying our front wheel wells and/or fenders. easy to do if you REALLY want that added height.
if RRO supplied a longer front strut to their existing kit, we 'may' even be able to fit 32's on our MK's. of course you still have to be concerned about added weight at each axle.
pros and cons......decisions, decisions :confused:
More to come from RRO
I talked to RRO today about whether or not they were looking into offering a higher end lift complete with shocks, etc. in the future.
They said it is something they are looking at, but that it wouldn't be available until after this summer. Perhaps they are waiting to see if there are any changes with the '09 models.
Good to know. i dont think i can wait that long tho. All of these posts about lifting the patriot is making me want to just order one now.
The whole deal with the angles on the CV axles is right. When you see a lifted late model chevy the whole axle is dropped to give the lift and proper angles to the cv shafts and this is not possible with a transverse mounted engine and transmission. The only two ways of achiveing this would be to drop the engine and transmission or design some kind of gear box at the wheel similar to the H1.
I'm down for the highest responsible lift possible, if that's 3", it's better than 2". Besides, I'm not looking to build a rock-crawling monster, the Patriot isn't intended for that. There are three schools of thought here; 1) people who don't care for a lift at all; 2) those who would like a little more clearance on a budget (spacer lift); and 3) those who could benefit from some additional clearance using replacement parts to ensure nothing is stressed-out prematurely.
To each his own.
unclejjg no I wish I did... but if you visit the main liberty forums you can view their talk about it... yet no photos because as you know the joints have boots so you can't actually see the joints..
Other options are Jeepin' by Al has some modified joints for the liberty that allows higher lift too...
Blitzbuggy, its impossible to do a body lift on a unibody platform like the Patriot since the body is the main component of the frame.
