Tie rods and rear control arms
2.2K views 4 replies 5 participants last post by  Earthworm51
Hello all,
I have wear on my drivers side inner tie rod and the rear upper control arms. Wondering your thoughts on what all I should replace. Should I just replace those showing wear or go ahead and replace both upper and lower control arms and inner/outer tie rods on both side of the front?
In order to answer a question better, it is always good to include model year, mileage, and any unusual operation aspects of your vehicle.
In general, I agree with DJMurphy. But, sometimes a single part can go bad prematurely and it is o.k. to just replace that part. An outer tie rod is a good example, and if you take care you can get that part of an alignment back to spec. on your own. One of the biggest challenges is finding good replacement parts. The traditional reliable companies like MOOG are going downhill due to bean counters and outsourcing manufacturing to third world countries.
The best way to learn what these components are is through Google to SEE and read about them. Tie rods are the connectors that go between the wheel and steering gear - turn the steering wheel and the tie rods push or pull the wheels in the direction desired. The control arms are part of the suspension that connects your wheel assemblies to the "frame" of your car. All these parts have to twist and turn multiple angles and have metal and/or rubber joints (think knee and hip joints) that can wear. And, everything has to be set up near perfect so your wheels travel straight down the road at 80 miles an hours.
If you can afford it and plan on keeping it then by all means fix all worn suspension parts that you mentioned and hopefully be done with it. I just replaced ball joints on my 1987 jeep comanche that i bought brand new. Will ball joints now days last 32 years i highly doubt it. My jeep comanche had the original ball joints on it. Here is an example for a tie rod for comanche $40.00 and change delivered to my house from o'reilly auto parts. Its made in china but i got it for a spare. A Moog tie rod delivered from o'reillys delivered was $100.00 and change. Dont know where it was made. The Moog ball joints i used were made in USA. Bought them from Rock Auto.
