I just traded my 09 Dodge Powerwagon with Icelander Green Diamond tires in for my 09 Limited 4X4 FDI
1) What is your experience in deep snow with the stock tires?
I live in Erie, PA and We already have had 120.3 inches of snow...
I live on a dirt road and get DEEP SNOW about once every two weeks. It's normal for me to get 8-12 inches of snow 2-3 days in a row.
2) The FDI doesn't have 4 Low Correct?
3) When I have deep snow I want to engage 4WD Lock? obviously the answer is yes.
4) I also want to go to Partial ESP?
(PARTIAL ESP
This mode is entered by momentarily depressing the “ESP Control Switch”. When in “Partial Off” mode, the TCS portion of ESP, except for the “limited slip” feature described in the TCS section, has been disabled and the “ESP/TCS Indicator Light” will be illuminated. All other stability features of ESP function normally, with the exception of engine power reduction. This mode is intended to be used if the vehicle is in deep snow, sand or gravel conditions and more wheel spin than ESP would normally allow is required to gain traction. )
5) In 4WD Lock, it will not disengage until I disengage it? This can be done on the fly, at any vehicle speed. and will not disengage itself at a set speed correct?
The set speed disengagement is for the ESP Off: In this mode, ESP and TCS, except for the “limited slip” feature described in the TCS section, are turned off until the vehicle reaches a speed of 35 mph and At 35 mph (56 km/h) the normal ESP stability function returns with the exception of engine power reduction. TCS remains off. When the vehicle speed drops below 30 mph (48 km/h) the ESP system shuts off. ESP is off at low vehicle speeds so that it will not interfere with off-road driving but ESP function returns to provide the stability feature at speeds above 35 mph (56 km/h).
6) So for the snow covered roads, I want to put 4WD Lock and Partial ESP?
This locks the center coupling allowing more torque to be sent to the rear wheels and when in Partial ESP, the TCS portion of ESP, except for the “limited slip” feature described in the TCS section, has been disabled All other stability features of ESP function normally, with the exception of engine power reduction.
7) I am debating if I want to purchase snow tires since I have until about April 1 until Winter is over for me?
If you have FF1 and drive snow covered roads is that how you roll, 4WD Lock and ESP Partial or ESP OFF.
Please give me your experiences...
I am thinking this is going to be pretty awesome...
Topcat
(PARTIAL ESP
Topcat
