Status
Not open for further replies.
*****RRO LIFT KIT ISSUES******
23K views 67 replies 19 participants last post by  Gaze
Hey guys, its been ages since I've been around here but I figured that you all should know about this.
Tuesday night I made a U-turn in my '07 Sport w/ the RRO Lift. Heard something snap then a clicking noise. I pulled over and found that the extension bracket for the Sway Bar linkage arm on the passengers side had snapped in half between the two bolt holes.
Now luckily I had a friend with AAA and a truck I could borrow for the day yesterday but this could have been an extremely costly issue for me (cost me the better part of a day at work as well). The linkage arm bent and is only a $55 (canadian) part but what if the now jagged edge of the bracket had gone through the sidewall of my tire if I was going faster? The linkage fell between the strut tower and the tire and rubbed the raised lettering off of my new BFG A/T's.
This is a major safety issue as far as I am concerned and I was quite shocked to find out that RRO must know about this issue as they have re-designed these parts and are now sending me two replacements. As far as customer service goes I was more than a little disapointed. I called yesterday morning and was told all they needed was my order number (stored in my work email) I came into work, a 30 minute drive, and called them back with it only to be told that I needed to send in a digital picture of the broken part in order to recieve a warranty replacement. I had to drive back home to get the picture. I was expecting some high turn around on this item so I could have my truck back on the road. I requested overnight delivery and was told that is not possible and it would be sent UPS (not comforting because UPS lost my first lift kit and the replacement for it took over a month and a half to get to me). I don't know yet if there will be any duty charges on these warranty parts.
Overall I am glad that I am getting parts for both sides since the other side is bent and has sever stress cracks in it already. This part is grossly underdesigned and they must have realised that to re-design it. I strongly suggest that anyone with the RRO lift kit have a very close look at these brackets and start registering your complaints with Rocky Road if they are bent at all. Get your replacement parts now because it sure doesn't seem like they are going to recall them.
For now (since I can't borrow the old man's brand new Chev for too long) I took some 1/4" thick (the RRO part is only 3/16") Stainless Steel Flatbar (its what we had at work) and made my own brackets. My Riot is back on the road but its unlikely I will be buying anything designed by Rocky Road again considering these parts broke under normal driving conditions, what quality is there behind their parts that get tortured off road?
Long post and a bit of a vent, but you all should know so this doesn't happen to you. Check those brackets!!!
Save
Oh that´s sad to hear. Hope you can get it fixed soon.
Save
Why would you want to do that? The part's been re-designed. :smiley_thumbs_up: The breakage is just part of growing pains - the guys running the lift are essentially on the bleeding edge. It's a risk you take with such a new product (both the Patriot and the lift). The customer service seems to be a bit disappointing, though, if past customers weren't notified, but right now there are no other options.
Save
Re-designed does not mean fixed though... Growing pains huh? What if it did go through his tire at 75 mph? That is a MAJOR safety issue... and it is an excuse to save $1,000 with the lift at around 400, tires 500 plus mounting. Not to mention the warranty. And really the kind of off roading I do hardly warrants a lift, I just think it looks better. I think I can get that look though with my other ideas. ;)
Unfortunately that is a side effect of moding your vehicle. aftermarket parts are never made to the riggorous factory specs, and sometimes things break. I think for this to be properly addressed RR should include longer sway bar links to compensate for the lift. Once again they need competitiong from another company with a more complete kit to raise the bar.
So what exactly is RRO replacing? Is it the extention bracket for the sway bar linkage arm? It sounds like it bent the linkage arm...is this being replace out of your own pocket through Chrysler/Jeep?
Some pictures of the orginal part, part location on the truck, and the re-designed part would be a great help...
Are there other lifted MK's with the redesigned part from RRO? If so, how is it holding up?
I don't think anybody knew it was redesigned, except for the people it broke, and who knows how many that is? Which calls into question whether it was actually redesigned. I canceled my order, and will be waiting a few more months on it... RR customer service sucks by the way.
Jim, I don't think it is blowing it out of proportion, we don't know his driving habits but they can't be worse then mine, I drive a good 75 mph on a daily basis, sometimes more. I live in a rural area where dirt roads are not uncommon, and in fact I play on them quite often especially in the rain, with lots of mud... and pot holes.
You are correct in saying we don't know the re-design date because they didn't send out a bullet on it, which they should have if there were any known problems, as a heads up, that's what businesses should do, they did not.
I have put about 7000 KM on my lift (I installed it in Mid January and have done several snowboarding and climbing trips since). Two months ago I had it in the Ghost Valley, a popular climbing destination in Alberta. There are roads of sorts but they are of the very large gravel or scree type rock. They are pretty rough but I could have made it in (with the exception of one river crossing) in my 1969 Caprice.
Potholes and speedbumps, nothing out of the ordinary for regular Edmonton driving. Nothing that is memorable at all.
The issue here isn't so much the part failing. I can agree with anyone saying that there are growing pains. Maybe its the fact that I am an engineer but looking at the part in retrospect I can see how and why it failed. The part is far to thin at 3/16 of an inch to handle the forces applied to it. One simple weld or making it 1/4" flatbar would likely be more than enough to strengthen it up.
There should have been something posted here. We are their testers as the first buyers of this product. In my opinion a good company would be involved with their customer base. Create a post asking how things are working and if any improvements can be made, let us know what improvements have been made.
I have pictures but I cant use photobucket at work. Will have to post later.
In the mean time I can forward them to anyone that wants to see. PM me.
Save
Thanks for getting those pics JeepJim... That was the other thing they could do to fix this problem. There are not that many of these lifts out there. This is definately a problem and personally I think they should be replacing these without any hassle for anyone who has the old ones.
The customer service comes in when I was forced to drive an additional 70 km's to get a picture of a broken part that they knew would break. The part breaking, fine, it cost me the money to replace the linkage and a day at work but its the picture that cost them any future buisness from me.
Save
This post has been deleted
just read your blog and was thinking of getting a K/N air filter ,How much of a differeces did it make, ps just bought 2007 steel blue patriot with 31000klm 4x4, power group ,yes fabric,anyway
Wrong thread dude.
Save
When there was an issue with a part they should have posted here about it. This is the forum that they used to rally support for actually designing it, its where people have reviewed it and talked about the quality and help others out with questions about the lift kit. I would guarantee that more (all?) have been sold in large part due to this forum.
Save
Originals were 3/16". That looks thicker than 3/16" to me.
Maybe a forum wasn't the way to announce the problem. Something should have happened and I am curious to see if they will replace non broken ones. Like i said, they demanded a picture of the broken part before they would warranty it and were un willing to ship the parts over night so I could repair my Riot. If I wasn't a little creative I would be without a vehicle right now.
Basically, it boils down to this: The product has been upgraded to address the issue. Be wary of RRO if you are someone that values customer service.
My experience has left me with a bad taste, if they start replacing them for people who have not had them break yet then maybe they would be worth looking at again. As it stands I will not recommend them or buy from them again.
Save
Well, I suppose its a good thing that it doesnt matter to me what you think I am demanding. Overnight to Canada is not impossible. I have done it in the past. Not only that they shipped it UPS standard, not Air or anything special, the same wait that it was lost the first time I ordered from them.
It certainly disabled my truck enough for the day that I missed out on $400 of work, cost me $60 or so for the broken part and two trips in and out of the city because they neglected to tell me they needed pictures.
Save
you stated the RRO mounting bracket broke and the extension arm bent... that in itself does not disable a truck. Now if it had punctured the tire that would have disabled the truck but only until you replaced the tire. The fact that the Sway bar can be disconnected and driven means your truck is not disabled.
I can sympathize with you for being pissed off but truly did you have to skip more than half a days work? I mean come on its four bolts to disconnect a sway bar.
Does anyone else feel he is asking too much or am I just a dick?
your just a ...... What time is it in germany anyways? you must be tired. :zzz:
jk everyones entitled to their opinion. We all react crazy when we are mad and he has every right to.
#26 · (Edited)
Missing a sway bar does NOT disable a vehicle, it just means that you should not try any high speed cornering unless you are a qualified driver. Many off-roaders don't even run sway bars because it can limit articulation. Model A Fords never had a sway bar and they weren't that popular up until the '70's.
Thank god for the notice
I have the old kit and the left front braket on mine was bending and I had to tightin my bottom bolt every two weeks. I just talk to JP and I'm going to send a picture of it to him so he can send me the new ones. I will also upload it in this forum too so everyone can see.
Save
When the drive is as far to work as mine is then yeah, it does take a good chunk of time.
You need to keep in mind that this was passed off as an easy to install kit. I am hands on as the next guy but I dont know all there is to know about suspension. To me Jeep decided this vehicle needed a sway bar for a reason. As a result of that I am not too keen on driving with out it, that is more than a fair reason for me to be unwilling to drive it. It was near 2 oclock when i found out that i could drive with out it, at that point the day was mostly gone.
Its pretty simple:
1) Their part was very poorly designed.
2) They redesigned it and neglected to inform their customers of the issue when, at highway speeds the issue could be a safety hazard
3) Their customer service department was not clear as to warranty requirements and gave me mis-information resulting in over an hour of driving time wasted
4) They would not make any effort to expedite getting the parts to me
As for the parts not being required clearly the sway bar is providing a significant enough function to carry forces strong enough to cause the bracket to fail in both bending and shear. As the owner of a new vehicle i was comfortable enough modifying this to the point I have, I am however not comfortable driving it with components disconnected. People need to be informed of this because i believe it to be a safety issue and possibly a very expensive problem.
Had i been on the road trip i am leaving on tomorrow and somewhere in the mountains with this a tow would have cost a small fortune, the replacement tire had the tire popped would be very expensive and road side would clearly not have covered it.
As it stands it sounds like at the very least one person has found their brackets to be bending and will hopefully have them replaced prior to being left on the side of the road stranded. You need a 17 mm and 15mm wrench/rachet to pull these out if those do break on you before you get your new brackets JeepNewbee.
I've pointed out the problems I have had with it, I believe thats the purpose of a forum. I expect better customer service, so i've simply stated that if you are like me that you consider what I have said.
Save
Quiff69 - I certantly do appreciate the info, my brother has a 2007 Pat and I fell in love with it, so much that I got a 2008 about 4 months ago, but about a month ago, the same thing happened to my bro's pat, the extension arm bent and don't tell him this....but I thought he had done something wrong, well, till this day, he's still waiting on his parts too and he's been very dissapointed, and I do thank you because it's algo good to hear the negative side of things as well... so I'm gonna hold off on getting a kit.
Status
You have insufficient privileges to reply here.
