rear seat bottom removal
12K views 4 replies 4 participants last post by  JoeyJeep
So my awesome gf bought be wet okole seat covers for front and back seats!
i just installed the fronts and the rear backs but the rear seat lower/bottom cover appears to require the removal of the rear seat bottom.
i looked and saw to huge star bit fasteners, one per side that attach to the body. Is this all that needs to be undone to remove the seat bottom or is there something else on the backside towards the cargo area? i didn't see anything but i did not look all that hard either after seeing the star bit fastener, which I don't have the right tool for..
thanks!
i just but the rear seat bottom cover on and the only bolts you have to undo are the two in the front, the t-55 star/torx bolts. You then just pull the seat away from the back and then bring seat out.
putting it back in wasn't exactly easy, just had to line everything up and sit on each edge as i found the holes lined up....
its in and they look fantastic....
