1 - 17 of 17 Posts
itsah2
· Registered
Discussion starter · #1 ·
I've been doing some research on towing with my '07 Patriot. I have the FWD 2.4L with the CVT.
I know I need the engine oil cooler to tow more than 1,000 lbs, but I was looking around and read that if I had the skid plate (which I do), I likely already had the engine oil cooler (I have the tow prep package?). I don't have a trailer hitch on the Patriot.
Can anyone clarify on this? What's the best way to tell if I have the cooler installed already?
Also, if I don't, is it a difficult install? I have an easy time with basic stuff (changing oil, spark plugs, etc.) but I haven't ventured into anything much more complicated than that.
Thanks!!
I don't think the metal skid plate ever came as an option on anything other than a FDII. I know tow hooks came on the All-weather group on the 2011, and maybe that included a skid plate. I am guessing the previous owner must have installed it, unless you have the plastic shield. I could be wrong though.
The best way to see if you have the oil cooler installed is to get under there and look! The oil filter mounts directly to it. If you reach up to the piece of metal your oil filter is attached to, you should feel fins on the sides of the metal, and it should look something like this cooler, although it is hard to see with a skidplate around it:
Hey you never know. I am pretty sure tow prep was an option on all 2.4L Patriots. It pretty much just consists of the oil cooler, wiring harness (came in a bag to install yourself), and full size spare
I wouldn't try towing with a 2.0L, especially no more than 1,000 lbs.
There is NO WAY I would want to tow much of anything with that 2.0L. I have the 2.4L, with the FDII pkg (lower gearing), and I just towed a U-haul trailer that weighed out right at the 2000 lb limit for 450 miles, through what passes for mountains in Missouri. I ended up with a MPG avg of 14.5. I think a 2.0, with it's higher gearing, would have been matted the whole time. A rolling roadblock. The FDII pulled the thing pretty well, handled and stopped nicely, didnt get hot, but I really had to get into the throttle to stay above 45 in the hills.
I agree completely.
I have an FDI w/ 2.4L and my boat setup runs around 1500-1600lbs( so under the 2000 limit ). I wouldn't want to try and tow much more.
Yeah... trailer brakes are recommend for loads over 1,000 lbs. Especially in the rockies! When I was towing a big load last fall, I had a choice of towing a uhaul that weight around 900 lbs with no brakes, or one that had hydraulic surge brakes but weighed 1200 lbs empty. I went with the lighter one, because I was afraid of over loading the bigger trailer... But I only had rolling hills to deal with
Glad you made it alive!
Totally ok to tow up to 2000 lbs with an oil cooler, as stated by the manufacturer. mrjeepr44, maybe your jeep is broken, cause my 2012 2.0 with cvt2 blows the doors off of almost any truck out there (0 to 60 in under 9sec), including v8 grand cherokees, and when towing 1000 lbs, it handles like theres nothing behind me.
...mrjeepr44, maybe your jeep is broken...
My Jeep has plenty of power and I'm quite happy with it, and it did a great job towing. Not sure where you got the idea I wasn't happy with it
Sent from my Nexus 7 using AutoGuide.com App
I don't want to start a fight with you( seriously ). My response is more along the lines of watch what you say or it will make you look foolish.
Point one is the Grand Cherokee is not a "truck". It is an SUV. A "truck" has a cab and open bed. You should not group multiple vehicle classes under one name. It is ok to call a CUV like the Patriot an SUV but calling( or implying )a Grand Cherokee a truck is totally inaccurate.
My 2nd point is that I have owned many V8 trucks in my adult life( muscle cars prior ). I have even owned a V6 model( 2005 Tacoma 4WD )and a 4cyl model( 88 Ram 50 4WD ). I now own a 2011 Patriot( 2.4L FDI ). Thus I have a pretty good field of experience to comment on your words quoted above.
I have to say, with all possible respect, that you are seriously fooling yourself about the performance of your Patriot. Now, my Patriot would certainly hold it's own with the 88 Ram 50 I had with the 4 cyl but it wouldn't blow it away. About even. Pretty much what I have seen from 4cyl Rangers and S10's. The Tacoma I had would easily out tow and out run my Patriot. All of the V8 FS truck I have had would destroy it in any competition short of passing gas stations( :D ).
I have to wonder, based on your comments, if you have ever driven a modern( late 90's + )FS truck and/or modern V6 & V8 SUV's? You seem to think your 2.0L Patriot is a giant killer. Most late 90's - 2007 or so V8's used in trucks and SUV's put out anywhere from 250-350+ HP depending on the displacement. Newer ones( 09+ )put out near to or over 400HP. Even the smaller V8 engines in FS trucks are now at or above 300 HP. If you have ever driven these types of vehicles I don't see how you could be trying to tell us that your Patriot is faster. :confused:
Your comments sort of remind me of the ricer crowd and the way they talk about their vehicles. You know, the guys who put a wing, some tribal graphics, fancy rims, and a fart can on their little Civics and suddenly think they have a road rocket. :icon_rolleyes: They act like they have something out of the Fast & Furious when what they have is from the Retarded & Ridiculous. Can't tell you the number of times a "rice rocket" would try and get me to race with one of my trucks( I dress them up and mod them out ). I just :doh: and ignore them as they zoom off sounding like a food processor on roids.
My last truck( 08 HEMI Ram 345 HP/375 FTLBS )could eat up a 2.0L/2.4L Patriot with me driving in reverse while eating a sandwich and talking on my cell in a 0-60, 1/8 mile, 1/4 mile, etc... run. That truck was a 4WD Quad Cab as well weighing in at over 5500lbs. Compared to many of the newer( 09+ ) models out there my 08 HEMI Ram would be under powered so a Patriot would be at an even bigger disadvantage. Any 2.0L/2.4L stock Patriot would be nothing more than an appetizer in a race vs most any modern V8 FS truck or SUV. Even modern V6 engines like Chrysler's new Pentastar are pushing 300+/- HP. A new Ford F150 with the 3.5L V6 Ecoboost is pushing 365 HP and 420 FTLBS. Think your Patriot can match up with that in a 0-60 or towing pull? A GC w/ the Pentastar would thrash a Patriot.
The Patriot is just not a speed vehicle. It can adequately get up to speed in normal driving but it is a far cry from a fast vehicle.
Third comment is that I would hope your Patriot could tow 1000lbs as if it weren't back there. A regular sedan can do that. There is a HUGE difference between towing 1000lbs and 2000lbs though. Put 2000lbs behind your Patriot and tow that for a while and you will see what a big difference it is. It is about as much as the 2.4L can handle never mind the 2.0L.
Again, I am not trying to be a jerk( I know it sounds that way but not the intent )but please do not compare the Patriot, of any variety, to "...any truck out there (0 to 60 in under 9sec), including v8 grand cherokees..."and expect us to agree or believe it. That is the furthest thing from the truth and if you had experience with trucks and V8 SUV's like the GC you would know that.
The Patriot is a great little CUV. It is ideal for daily commuting( MPG ), family use, some off roading, and minimal towing. It is not a 0-60 rocket nor is it a towing machine. I love my 2011 model so this is not any slam on the Patriot. Just asking you to use some common sense when posting.
:beerchug:
@NHPATRIOT
I'd have to go with you here dude.
I have a '96 Suburban 4x4, 35" tires, 4x8' roof rack, front winch bumper, only a 5.7L, 350V8 Vortec weighing on over 3tons unloaded smokes my 2.4L patriot.
As you stated,....less passing a gas station. LoL
2012 Patriot Sport 4x4
If you can change oil and spark plugs like you mentioned then you can install the engine oil cooler...I added it to my '09 with no problems by myself in an hour or two.
I would Never go above the 2000lb limit towing with the Patriot for any lenght of time. I have pulled my 6x10 enclosed trailer around town once or twice over the limit and it "worked" but I wont do it again. When I stay under 2000lbs it pulls my trailer like a dream, but not when its full.
misunderstanding
I wasn't clear when I said almost any truck. I did not mean high performance trucks, that would just be dumb. I agree it is no rocket, and wont compete with expensive performance machines. But it is quick with the cvt and no weight from a frame, transfer case & other associated 4X4 parts. I was just trying to point out that the vehicle will pull what the factory says it will.
1 - 17 of 17 Posts
