1 - 3 of 3 Posts
Hudson81
· Registered
Discussion starter · #1 ·
Hi everyone. I just purchased my 2007 Jeep Patriot 4x4. It is equipped with the 2.4L engine and CVT with opt DAW off road crawl ratio. I need any advice possible because my Patriot will not shift gears. It has a check engine light with codes P0730 and P0700. It has normal engine power and isnt sluggish at all. It just will not change to a higher ratio and cannot be driven faster than 5-10mph because the engine just keeps reving with no gear changes from the CVT. Any advice is appreciated
Did you ever resolve this issue? Have same issue and need to know what was replaced to correct issue.
Thank you,
1 - 3 of 3 Posts
