No crank, no start
159K views 52 replies 20 participants last post by  somewhereoutfar
Well, another year, another major problem with the Pat.
Two weeks ago, I went out to start it and it wouldn't start. No crank or anything. Battery is nearly new, all lights lit up brightly, radio worked fine. I looked into it and there is a TSB for the wireless control module, and a simple quick fix is to disconnect the battery for 30 seconds and reconnect and that will reset the WCM.
I did that and the Pat started up right away and ran and started just fine the next few days. A few days later, same thing happened and the disconnect/reconnect method worked just fine. But this past Friday, it happened again but no matter how long I left the battery disconnected, it didn't correct the issue. The Pat will not start. Fortunately, it was parked in front of my house at the time and not out somewhere.
I'm still assuming this is a WCM issue, but has it been known to just quit completely?
I have an appointment at the local Jeep dealership, but they can't even get to it until the 20th (!!!), so we're stuck sharing a car until then. Based on the TSB, they quoted me over the phone $130 for the part and another $150 for labor, but who knows what other "problems" they're going to find along the way.
I should have traded the damn thing in last year once I got the last round of problems finally fixed. :doh:
Will do. I may have to try to manually crank the starter. The first time I popped the clutch from a roll and it started, but this last time it didn't work and my Pat ended up at the bottom of our hill and I had to use the wife's CRV to pull it back up to the house :lol: Maybe I didn't get a fast enough roll that time or something. Ugh...
Nothing would surprise me with this damned thing. When you added push button start, which wire is for the starter? Was it all in dash or under hood?
I did it many years ago on my old neon, but tech has changed and I'm not 100% the method is still the same. I just want to hot wire and see if it cranks bypassing the wcm.
I spliced into a wire directly at the tipm. Cant remember the colour right now exactly. But it was in the small brown connector. If you can wait a few hours I'll check my wiring diagrams. Im a 2hr drive away from my vehicle and wont get a chance to be back to look at it until tomoro or the next day.
Cycle your key 3 times see if it throws a code though. Mine showed p1279 starter circuit 2 open.
I'm not that great with these wiring diagrams, so do a bit of testing if you can but I think it was a yellow/grey(wire #8 in C10 Connector). Just trace it real quick make sure that is the one that goes to the starter. If you can test it to see if power is running through it. Also I just noticed your other thread about headlights. If all you problems lead back to the tipm, Dorman Manufacturing makes a tipm for much cheaper for your 07-09. They have a video on youtube also how to program it to your vehicle.
Well, I was looking around on here and happened to find several people that had the same problem as I did, and the problem was the black relay box down by the driver side wheel well. I popped it opened and sure enough, one of the relays was corroded and had a pin broken off. I'm not going to get around to really trying to fix it until tomorrow (damn my wife for waiting until the last minute to do taxes, so now I'm doing them this year).
Hopefully this will be the fix I need. The other thing that gives me hope is that there is no security light when I try to start it, so that might disprove the WCM failing.
That black relay box you mentioned. I checked mine too, was slightly corroded cleaned it up and a few other wires and then it showed the code I mentioned. But none of mine were broken. I don't have the security light show up either.
One of Three OBD2 Code readers found that my vehicle was not recognizing the key turning to the start position so this led me to believe either ignition switch or bad wire.
I bought a patriot that wouldn't crank .I dug into everything I could find on the net ,and from what I was able to figure out ,the wcm is not your problem as it should show a security light ,and it should start for a second then stall ,and as far as I can tell ,yours doesn't crank .I ran a push button to the yellow starter wire and it works fine now. My relay box had one relay that was green in the contact area ,I replaced it and checked the wiring connections ,but none appeared bad and I never found a diagram of the relays to see what was going on with them .My relay that appeared bad was the one in the corner that did have another beside it ,is that the one that is bad in your case ?
The relay dance didn't help me ,you have nothing to lose by trying it with your fingers crossed .
Yes ,the little yellow wire off the starter ,remove the intake tube between the air filter cover and the throttle body ,the wire is fairly easy to get to then .I used a inline fuse coming from the battery positive ,through a firewall hole to the switch ,back to the battery area where I installed a 40 amp relay .Took about 15 minutes to wire ,mount the switch ,and confirm working .I put the switch right beside the key on the 1" flat part of the dash .
Not sure but don't think so ,the small terminal that's right up next to the engine block is the one you want ,the connector is backwards if looking through the area the air tube was ,just push the terminal straight to the passenger side of the car ,then tug a little on the wire and you will be fine .I am 6'5" and 240 lbs ,I had to work getting my girlie hands in there but in the end I got it with no issues .I still haven't put any of it back together ,I will see if I can get you a picture or two tomorrow ,but it is supposed to pour all day .
Ok, I found the wire. Before going through the trouble of wiring it all up, I did a hotwire test first and while the starter will crank, the engine won't fire at all. So, it is more than likely a TIPM or WCM issue afterall.
But the lack of the security light being on (just for a few seconds when turning the key), all but eliminates the WCM.
Thanks for the heads up, but unfortunately I don't think this is my issue. I've attempted to bypass the ignition (turning the key to run, but feeding power directly to the starter). It will crank then, but still won't start. My issue has to be the sentry key issue, or it's some deep-seated electrical problem.
However, this sounds like a possible solution to the problem you guys posted in here.
I wouldn't blame you either. I lost my temper a bit last time I went to the dealership, cleared out the service department lol. But I'm convinced its not the tipm in my case and that's what they wanted to changed for $1300 plus labor.
My friend and I are doing a road trip tomorrow to pick up another roadrunner for him ,Mother's Day is Sunday but I will pull my column apart if I have time and ambition and see what we have got going on in there .I will say ,my key has a nice twist so I wouldn't be surprised if something is physically broken in there .
Let us know how that goes. I'm 5 days away from seeing mine again but its top priority when I get home. It has to be something in there for me since it doesn't acknowledge the key being turned to the start position. And I think I know what you mean by the key seems twisted a bit, mine is a bit plus mine wiggles slightly in the ignition. Maybe lightening up the key chain would help me prevent this problem next time, if it is the case.
#33 ·
