I've been told that if I install a reversing camera that I can no longer have Uconnect does anyone know if this is true?
Patriot Sport 4x2 CVT 2013
I do agree with this. If you can find out which wire is the mic, you can wire in your own mic, and problem solved! I actually like this idea better, id go for it! I can tell you the uconnect plug will be the middle small plug behind the radio, one of those wires is prolly the mic. If you cant figure it out, then one of the wires up by mirror would have to be a mic, and that should be easy enough to find.I wasn't thinking about the camera kit that displays in the rearview mirror. Yeah that could be an issue with the UConnect if it doesn't include a microphone( I would think you could add a microphone though to the appropriate plug in spot on the back of the head unit like you would if adding UConnect to a vehicle that did not come with it? ). A regular camera run through the headunit though and it won't cause any issues.
I dont see why this wouldn't work. The uconnect system would not be disabled, you just wouldn't be able to speak into it. But if you buy the mic and plug it in, you should be fine. If you let the dealer do it, make sure to tell them to leave the uconnect system alone, and do not disconnect anything from it except the mic. Either way this should still be an easy fix.cravens;
http://www.oemautopartsco.com/uconnect-factory-mini-microphone-p-51.html
http://www.oemautopartsco.com/index.php?main_page=product_info&cPath=1059_1_7&products_id=52
No guarantee these will work but they might. These plug into the factory location and seeing as you have UConnect now "maybe" the mic slot is active and will work? I believe the mirror mic runs off the same slot so it should work but you never know with this stuff.
