You can't use the STU's and a RRO.... Ask failwheeldrive. He can tell you why
I got a couple PMs on this that I think were prompted by this thread so I'm going ahead and putting my 2 cents in: :blah:
I think the Stu's/RRO combo is "
possible"...
It's just that a couple other suspension pieces would have to be upgraded as well for it to work & be reliable.
Since both the Stu's and RRO kit individually push the ball joints and CV angles just about to their limits, combining them would cause issues. The CVs would
probably start binding up right away, or at least when you tried to accelerate, and the BJs would likely fail pretty quickly because they'd be operating at an angle that they just aren't meant to. Tie rod angle might be an issue too.
I do have a simple idea that
might solve the angle issues of the combined spring/spacer lift pretty inexpensively... keep in mind that it's just an idea at this point and pure speculation:
Create a second set of spacers to space the front and rear sub frames away from the unibody.
The top of the struts mount to the body, and the bottom to the lower control arms. By increasing the space between the body and sub frames the CV/BJ angles should decrease.
This idea could be proved (or disproved) by simply putting a Patriot up on jack stands, putting the front sub frame on a jack, removing the sub frame bolts, and seeing how far you could safely lower it down until things like a brake/coolant/clutch/wiring/fuel line become a limiting factor. Of coarse while doing this watch to see if the CV/BJ angles change. Then make a spacer this size (who knows even 1/2"-1" could make a decent difference and allow a bigger lift or the spring/spacer combo).
Now you might be saying, FailWheel why would we want to drop the sub frames... won't that decrease ground clearance? The answer is yes that it would decrease ground clearance at the sub frames, but it would still lift the body up and help out approach angles. Plus it
might allow bigger tires to be fitted.
If this idea worked out a company like RRO could easily just figure out how far they could space the sub frames and then make their strut spacers larger until they were just under pushing then CV/BJs to the limits again.
If this worked for the Patriot it might end up being smarter to combine both the spring lift and spacers. Since different Patriots have different springs from the factory, it would take that X factor out of the equation so one kit would fit all Patriots.
Maybe only one brake line is the difference between 1/2" and an 1" and it's not too hard to replace. Maybe you can barely drop the subframe without wrecking stuff. Maybe it can be dropped 2 inches with no issues.
It's one of those things we just won't know for sure until someone tries and even then I'm sure it will take some trial and error.
Maybe someday I'll drop my front sub frame to see how far it could go and how much of a difference if would make.
How sick would a Patriot with a 4" lift and >30" tires be? :rockon:
Then again >30" tires might be too much weight and too much from a gearing perspective so it might just not be worth it.
