Need advice on new Patriot Purchase (07 vs. 08, 2.0 vs. 2.4)
1.7K views 8 replies 7 participants last post by  mitakuuluu
I would say you want the added power of the 2.4 (plus I don't think you can upgrade the 2.0 to do 2000# towing if you decide you want it later). If the dealer has a ton on the lot, might as well test drive it just to compare and put it through its paces (accel to get on highway, accel while at highway speeds, etc)
4x4 vs 4x2 is a big question that I can't answer for you. If you are comfortable with your snow level in 4x2 and most of your boat ramps are okay in 4x2, then it will save you on gas and 4x2 is typically less expensive to insure as well (check w/ your insurance company to see if it matters where you are). OTOH, Oregon sounds like big snow country to me.
Too bad you have to go the auto route, I love my 5 speed!
You can always "build a 2008" at the dealer (maybe one you aren't purchasing at), hopefully they will do better on prices/packages that way so you can compare to the 07s avail in your area. I agree with hunter, adding a MOPAR or other cruise control later should be no problem.
Good Luck!
