1 - 1 of 6 Posts
On the Jeep Liberty, the front sway bar was the culprit. Make sure the bolts are torqued to spec AND grease the "rubber/poly" that the Sway bar passes thru where it attaches to the body. many Liberty Owners ended up drilling thru the metal/poly and inserting a grease zerk. Also check the torque specs of the strut bolts on the top of the struts.
1 - 1 of 6 Posts
