High RPM's
23K views 35 replies 20 participants last post by  gdasher
Why is my patriot reving at 3000 rpm's at cruising speed? Help me out here.
I'm assuming you have the CVT2L, if so all of ours do this, there are multiple threads on this, but the short of it is the CVT2L has a higher final drive ratio which causes the RPMs to be higher then the regular CVT2, you can expect to hover right under 3k at 65MPH
I average in the low 20's for my MPG. when I'm around 65MPH lately its been around 22MPG
its close 68MPH right in that range I was talking about. Unfortantly CVTs don't have and "overdrive" and I have not seen a software update to compinsate for this, I wish there was. As much as I like the smooth ride in the CVT, I think the Patriot would be much better if mated to a regular tranny
#15 · (Edited)
There was a Technical Service Bulletin (TSB) for the '07 Patriots to reprogram the engine and/or tranny electronic control modules. It applied to vehicles built before a particular date. It may be worth PumP_3A's time to get the dealer to check it out. It is in Chrysler's interest to make sure it is right to minimize their warranty costs.
The original EPA figures for the '07 trail rated 4WD with CVT2L were 21 city and 23 highway. The revised figures per the 2008 test protocol are 19 city and 21 highway. The 2008 Trail Rated Patriots are a little higher at 20 city and 22 highway. You can check the figures at this website.
http://www.fueleconomy.gov/feg/findacar.htm
FWIW and IMO and YMMV. :)
FDII high revs
So I'm curious- is there anyone from (or knows) Jeep engineering out there that might know answers to these questions- I'm sure there are lots of FDII owners that would LOVE to know:
1. Is there a reason the an FDII transmission HAS to rev high "at highway cruising speeds"? I understand the need to rev higher for off roading (which my Patriot does nicely), but shouldn't it be possible to rewrite the software to lower "highway speed" revs and help out mileage at highway cruising speeds?
2. If not, might it be a possibility to flash a FDII computer with FDI software so that it would lower the revs at highway cruising speeds?
You can't change the gear and final drive ratios since they are mechanical pieces, and don't relate to anything within the computer. Maybe you can change the shift ratio (shift points) by flashing the chip?
The CVT only has some much range of adjustment to create drive ratios. With the Off-Road pkr your get the super high final drive differential gearing. The diff gearing is what you are noticing. The STD trans get 4.12's the basic CVT gets 6.12's and the CVT2L get a crazy tall 8.135 diff pack. The higher the ratio the higher the rpms at any given transmission ratio. The only possible fix to your problem would be to get the shorter diff gearing but you will loose torque in low range.
What are people revving at with the 5 spd? At 110 kph i am around 3000RPM too.
#36 ·
I have an 07 5 spd and at about 70mph it is around 2800 RPM to 3000 RPM as well. You would think that if the RPMs were that high they would just toss in a 6spd like in the liberty or wrangler.
#28 · (Edited)
The 2008 5MT 4WD Patriot I test drove did 2150 RPM at 60 mph which means about 2500 RPM at 70 mph.
On the 2008 CVT2 2WD I test drove, the RPM at 60 mph varied with whether I was on the level or going up a slight rise.
Well that seems alot better than what i get, i payed attention today and im at about 2850 for 68 mph (110 kph). I wonder why im revving so much more. Being a 5-spd it shouldn't slip or anything so having some more resistance from my roof basket and lights shouldn't matter, or am i wrong on this?
The other day I was picking up speed on a very very short on ramp. The Jeep reved all the way with the needle buried. The engine was making a very loud rev noise too. I let off the gas quick. I can't see this being too good for the drive train. I have the CVTII.
I haven't tried this myself, but I've heard that putting the pedal halfway down and letting the CVT shift down and then putting the pedal down further works better. Also, you might have your dealer check and make sure you have the latest engine management programming.
For better or worse, I understand we have electronic throttle by wire, and shift by computer with the CVT models. :)
#35 ·
My 4x4 (non Trail rated Patriot Sport ) with CVT cruises at 60 mph using 2,000 rpm. My 03 Toyota Camry four speed 4 cylinder automatic cruises at 60 mph and also runs at 2000 rpm. Since 4th in the Camry is an overdrive gear, I would have to say that I feel the CVT does have overdrive, you just don't see it listed on the shifter.
The Camry is very efficient and gets 30 mpg on the highway and about 26 around town. My Patriot gets around 22 around town and 27 on the highway, which is not bad either.
