I have no lights or indicators when I press the heated seats buttons. They don't appear to be functional. Is there a guide here that might help me troubleshoot this?
If it turns on but doesn't stay on it's not a fuse. There is a timer or relay in the circuit that after a period of time switches the setting from "hi" or two lights on on the switch, to "low" or one light on on the switch. Then finally to off after a predetermined amount of time at each selection. You can find an online copy of your owners manual and wiring diagrams that should help you narrow down that timer relay. Once you locate it you can swap the timer relays for the two seats to see if the problem follows the suspect relay. Then you will know for sure prior to ordering or otherwise purchasing the part.i have the same issue in my 2008 Patriot North edition.
The driver side turns on but doesn't stay on. The passenger side does stay on and works properly. My driver side will work once every million tries. I don't have the owners manual, so im not sure what "fuse to look at"
That's, however I had to repost a greater problem! My hazard lights are not working! It seems nothing on that switch bar is working. So, I'm leaving this problem as a secondary issue. My hazard lights are a bigger problem for me.Here's some resources for your 08 patriot
1. Will get you the wiring diagram
2. Will show you the heated seat switch
3. Will show you the heated seat module.
Sent from my SM-N950U using Tapatalk
source: https://workshop-manuals.com/jeep/p...ter_control_module/component_information/description_and_operation/description/The heated seat module (2) is located under the left front seat. It has a single electrical connector (1) and a push pin style retainer that secures it to the
seat pan. The module can be accessed from under the front left seat with the seat in the full back position.The heated seat module is a microprocessor designed to use the Local Interface Network (LIN) data bus messages from the instrument cluster also
known as the Cabin Compartment Node (CCN). The CCN receives inputs from the heated seat switches and in turn signals the heated seat module to
operate the heated seat elements for both front seats.
source :https://workshop-manuals.com/jeep/p...rol_module/component_information/description_and_operation/description/page_77/Seat Heater Control Module: Description and Operation
OperationOPERATIONThe heated seat module operates on fused battery current received from the ignition switch. The module is grounded to the body at all times through the
electrical connector. Inputs to the module include Local Interface Network (LIN) data bus messages and standard hardwired 12 volt power and ground.
In response to the LIN inputs the heated seat module will control the battery current to the appropriate heated seat elements.When a heated seat switch LIN data bus signal is received by the heated seat module, the module energizes the selected heated seat element. The Low
heat set point is about 38° C (100.4° F), and the High heat set point is about 42° C (107.6° F).In addition to operating the heated seat elements, the heated seat module sends LED illumination messages to the CCN via the LIN data bus. The CCN
then sends the LED illumination message to the accessory switch bank so that the appropriate LEDs are illuminated for any given heating level. Pressing
the switch once will select high-level heating. Pressing the switch a second time will select low-level heating. Pressing the switch a third time will shut
the heating elements off.If the heated seat module detects a heated seat element OPEN or SHORT circuit, it will record and store the appropriate diagnostic trouble code (DTC).
source :https://workshop-manuals.com/jeep/p..._heater_control_module/component_information/description_and_operation/page_78/Seat Heater Control Module: Testing and InspectionHEATED SEAT MODULEIn order to obtain conclusive testing, the heated seat system and the Local Interface Network (LIN) data bus circuit must be checked. Any diagnosis of
the heated seat system should begin with, the use of a scan tool and the appropriate diagnostic service information. Refer to the appropriate wiring information for complete circuit schematic or connector pin-out information. NOTE: Vehicles equipped with the heated seat option utilize a low voltage cut-off feature. This feature turns off power to the heated seat
system anytime vehicle voltage is below 11.7v or above 15.5v. Be certain to check the vehicle electrical system for proper voltage anytime the
power seat system appears inoperative.Before any testing of the heated seat system is attempted, the battery should be fully-charged
Cruise Control Accel and Resume buttons don't work. However SET will.OK. I thought that was resolved. Sorry about that.
Let's work on this. Please list all non-functional features and we will find a common link.
I think you are looking at it the wrong way. I think it's under the driver's side... If you blow up that image you will see the steering column on the right side. So the view is from the outside with the firewall transparent. At least that is what it looks like to me unless this is a european right side drive model. I will try both sides.. so a hunting I will go.All other features and function work w/o fail? C201 appears to be behind the glove box. Light grey connector with 43 pins/cavities
