Hi there,
Does anybody know if our Pats have a fuel cut-off programmed in the ECU ? This is the feature allowing to cut fuel to the injectors when coasting in gear above a certain RPM (usually 1500).
I heard that the newer models have it, but not the older ones. Mine is a 2009 manual awd.
Is good to know in order to adapt your driving style to maximize mpg : if you don't have it, you better coast in neutral to preserve momentum. If you do, coasting in 5th gear saves more fuel (and brake pads). I live in a region with a lot of hills and I think it can make a difference.
