Factory MyGig HU with aftermarket AMP
2.9K views 5 replies 2 participants last post by  Kahbrohn
Has anyone hooked up their MyGig with an aftermarket AMP? If so, how did you hook it up? Wiring harness?
For what I have searched here, installed amps were donw with aftermarket HU's as well.
i havnt done it myself but easiest way is to get a speaker to line converter just takes the speaker wires and converts to rca outputs youll need 2 stereo units for front and back, i can pick them in aus for 15 dollars each
So, speaker wire to these converters... these converters to the amp... and then from the amp back to these units? Any idea on the effect of quality?
no they convert the speaker levels from the mygig(anyradio for that matter) to line level so you can input into the amp then the amp connects to whatever speakers you want to use
