2007 model CRD Limited. Owned since new. Not been a problem before but yesterday when going doe the motorway, the light came on with a chime of 1 ting, loss of power, then reduced power but continued to run.
Power came back but not to normal levels (turbo engine). Coming home from work, the light is still on though very low glow. Power seems about normal.
Responded to calls for power when accelerator pressed.
Now, battery is 7 years old and does need replacing as last night the lights could be seen to be pulsing. I assune this is the engine charging the battery, switching out when charged and battery requesting charge again.
Could this be the pissble fault? I know there have been problems in the past with turbo pipes coming loose. The engine was fare old messed about last year during service, having the filters etc changed and major service completed which included a new radiator.
Any ideas to this one chaps?
Is the Patriot OBD2? Need to consider buying a cheap reader.
Many thanks in advance. Would al,so add that yesterday was a fairly hot and humid day, around 23 degrees yesterday going to work. Cooler in the evning.
Look forward to the input
edit:
I shaould add that this light came on when I increased acceleration from cruise to pass a lane hogging car, around 80mph.
edit:
