Creaking front suspension...
53K views 63 replies 52 participants last post by  kaneo465
Anyone else? Just turned over 16,000 miles on my 2007 and notice a significant creak from the front when rolling over speed bumps and the rounded curb into my driveway.
Probably has something to do with the couple high-water creek crossings and getting it stuck in 13" of mud on a few trips. I'm going to have the dealership take a look at the next checkup... just curious to know if anyone else is experiencing this.
mine does it to, but its been doing it since like 4-5000 km, now i got 23000, but from what i think it is, i think it is the door seals and body flex im guessin
Woodturner, I've had the exact same issue for a long time now. A very slight creeking when I turn sharply at slow speeds. I really don't mind because I can't even hear it with the radio is on. Did the dealer make this out to be a big deal? Something that must be fixed? It's not getting any worse or louder as far as I could tell.
I'm getting creaking from the left rear. When I open the rear hatch and push up and down that's how I found out where it came from. Also when I have no load on I get clunking from the rear when I hit any kind of bump. Sounds like the old days when the shocks were finished. I've got 27 klms and will have the dealer take a look at the next oil change.
I had a little creak and groan coming from the door seals. I gave them a quick wipe with my Ice Wax application rag the other day when giving my Riot a slick coat and that stopped them seals from talking to me over every speed bump or body twist.
A little lube never hurts!
Have my 08 Pat in for service as we speak. Had pretty much the same symptoms but had quite a bit of "creak" as it slowly accelerated from a stop. Just got off the phone with the service dept. and they said they would be replacing the sway bar bushings. I'll report back after I get my Pat back.
#61 ·
I have the same problem with creaking turning at slow speeds and sometimes over bumps. Its pretty lound and there is ratteling. The mechanic wants to replace the arm for 350.00 sounds like its too much.
I had same problem with 2008 Patriot from day 1 (now at 1600km).
I noticed the noise came when hitting a bump or hole, but mainly at rapid/stiff shock movement. It was worse when I hit bump/hole while going in curve to the right.
No noise at other time when suspension travelled slowly.
However when that noise came out, it was like a dry/sharp metal-to-metal noise. Also when driving on a gravel road, it sounded like if I had a metalic box filled with hardware that was rattling under the dash.
I brought it at dealer and managed to reproduce the sound next to the technician.
They simply tighten bolts on the left link arm and left lower tab.
They had seen same problem once before on another brand new Patriot.
Now the sound is gone!
I used to have a creak in the front at speed bumps too. Now my Patriot is lifted and the creak is gone. :)
Plenty of *squeekedysqueekedysqueekedy*-sounds coming from it nowadays, though... Part of it is guaranteed to be the gear in the trunk, but there might be some squeeky parts on the car itself, too. I guess that's just par for the course - it's a cheap Jeep. Can't expect everything to be absolutely quiet, I suppose?
Eeeps grinding noise here too.
What I had hoped was an esp without light issue is now a sharp left turns issue.
Thing is it is not constant enough to take my tech for a test drive to prove it.
*sigh* not looking forward to the dealer runaround.
Especially since my dealer is next to worthless.
If you spray the strut mounts at the top of the shock tower with some white lithium grease this will often relieve most squeaking noises. If you want to get a little more detailed get the appropriate socket and johnson bar and use the nut at the top of the strut to work in the grease, do not remove the nut! Just work it in back and forth. The only other noises i've noticed is just some of the interior dashboard pieces rubbing together, nothing substancial.
I have the same noise everytime I hit a pot hole or speed bump. I've taken mine to two different Jeep dealers both say they couldn't find a thing! I just took it to Midas and they said it's the left tie rod! Unreal. Midas can find the problem but dealer can't? Also when I had my leather seat split Jeep dealer didn't want to replace it. I think my dealerships just don't want warranty work on the books. I now need to find another Jeep dealership. I'm beginning to hate Jeep Dealerships altogether now.
Anyways Deltaboy if you could just ask them to look at your tie rod and see what they say about that. I'll have them look at the bushings etc just to make sure. Thanks.
Coming from the rear end after lift??
That's the new control arms. I had the same issue.
get a good quality lube and give the control arms a good lube.
Especially the rubber ends and the bolt that goes into the arms and tightens to the frame. Will take a few k's to go away. Mine took about 3000km's.
Also lube the sway bar rubbers.
I still some times get the noise only while giving it good articulation in the bush. But on the roads and bumps all quiet no probs..
When I put the lift in it was loud as fark. But a good quality lube fixed that. Make sure its water proof also.
is this issue fixed with the 2009 Patriot?
So the 2009 Patriot is supposed to have an "improved suspension" as they advertise...does anyone know if Chrysler issued an internal fix to the 2009 version? I would like to know because I just got a new job offer in north jersey and most likely will be taking advantage of the military discount and graduate from my honda civic to a jeep patriot. it would just be nice to know if chrysler fixed this with the 2009 version's "new and improved suspension"
thanks!
-josh
My front suspension makes a clunking noise over speed bumps to. I've mentioned it to the dealership and they will look at it when it goes in for servicing next week.
They are also going to look at the faulty cigarette lighter and the minor pull to the left when driving.
Creaking being fixed... Overnited parts...
Dealer is currently fixing my "creaking front suspension" They diagnosed it as the sway bar bushings are bad. I know a lot of these problems have had different fixes, but I am pushing 21,000 miles, so I'm taking it in for everything now. GET THEM FIXED! It's all under warranty. Just blew my first fuse too, might look for the thread on that....
