The oil normally has nothing to do with a DPF. Oil does not normally effect a DPF if fitted. The PD engnine (assuming that is fitted to Australian Models as it is to the EU ones) is not really suited to a proper DPF, so if one is fitted as an option I would seriously question its efficiency and longevity. If anything a thin oil is worse for a DPF as it increases oil burnt.
I keep seeing people say a DPF is/has been available on the 2.0 engine but I can find no information on this, and I suspect its a rumour. If it had been the case and an effecitive DPF was fitted then this model could have been able to be sold in all US states which is is not and would be Euro V compliant (which it is not) and the change to the 2.2 Merc engine to meet obligatory Euro V compliance from Oct 2010 would not be needed.
I have in another post explained why the PD engine needs this supposed high spec oil due to the need to protect the cam actuated injectors, but I believe that 5-30 does appear too thin and for better turbo wear and other components then a 10-40 or 15-40 may be better. I intend to use 10-40 semi in the future.
However, a regular oil change with any oil is better than infrequent ones with "high spec" oil. I would be more inclined to change the oil more often on vehicle that is low mileage and does a lot of short journeys than a high mileage long trip vehicle. Remember more engine wear occurs in 2 mins from cold than two hours at high motorway speed.
Personally I would use the manufacturers reccomended oils if the vehicle is under warranty.
But where do people get these fancy oil specs from?
I am sitting here with the manual from my UK 08 vehicles which states on page 154 (and repeated on page 137)
Diesel Engine (ACEA A3/B3, A3/B4, or A3/B4/C3; SAE 5W-30, SAE 0W-40, SAE 5W-40, SAE 10W-40, or SAE 15W-40 Engine Oil.) No other specifications are mentioned especially a VW spec nor is any other spec written on the filler cap or engine bay.
My research seems to suggest that A3/B4/C3 is equivalent to VW 505, but as you can see lower spec A3/B3 and A3/B4 are also reccomended.
