Hi folks,
I have a 2009 manual transmission and I experience hard shifting in the 1st gear. I tried all sort of things: lubricate the cables, change the transmission oil, bleed the clutch circuit, the problem is still there.
I want to tight a bit the clutch pedal in order to put more pressure on the clutch. Just a little bit, I know the pedal has to keep a certain loose. Do you know if there is a bolt somewhere for the clutch pedal adjustment ? A picture would be highly appreciated.
Thanks all.
Thanks all.
