Bug-out vehicle
4.9K views 11 replies 10 participants last post by  u35828
How many have built or installed items in their Pat to equip it for moderate survival/search & rescue/natural disaster/zombie apocalypse scenarios? What did you include in your build? What kind of tools or supplies and where were they installed? pictures appreciated.
don't forget the power bars or equiv. They have a long shelf life, and if stale, they will chew longer....
In my mind the Patriot is not a good choice for that type of vehicle. Simply put it doesn't have enough range. I mean if you were in south Florida and a hurricane was bearing down on you, you wouldn't be able to get more than about a state away before having to stop for fuel. There are a lot of vehicles out there that can easily achieve a range over 500 miles on a single tank of fuel. A WK2 Grand Cherokee is one example. In all of the typical "Prepper scenarios" you have to take into account that supplies and resources would be hard to find or simply unavailable. So relying on a vehicle that can't even get 300 miles out of a tank of gas in most situations seems counter productive to me.
That being said, for most of us, a small tool kit and a "go bag" with water, blankets, extra socks, and some small supplies is all we really need and is easy to assemble and can even fit in the spare tire compartment.
I am in no way a "prepper" of any sort. I do have a tool kit and some supplies that I keep in all vehicles I own because I was once on a highway that got shutdown in a snow storm for about 10 hours. That's a life changing event.
i have 2 vehicles, patriot having 217k miles on it and 200 miles to the tank would not be my preferred bug out vehicle
my buick sedan with 68k miles on it gets 500 miles to the tank, that's the vehicle I would take in an emergency
either way I camp a lot so always have a bag with camping stuff in the vehicle,
I don't carry water often but do have a water filter in the bag, along with other gear,
for food, I usually end up eating the jerky and snack bars before any emergency, but I do have dried meals along with canister stove in the bag
Sterno, matches, extra hoddie, sunflower seeds, twine and jumper cables. Keep the items in the spare tire bay, with the spare tire. In the right storage area above the spare tire deck, small portable air compressor and tow strap.
My Patriot contains the following:
Fire Extinguisher
Go Bag- water proof matches, flint and steel, water purifier, leatherman, combat knife, tourniquet, quick clot/Celox, toilet paper, hand sanitizer, emergency gps beacon, and med kit
Solar Generator with battery terminals, air pump, and usb charging
Toolkit
Some sort of firearm (usually on my person)
Spare tire
If anyone has any good ideas for fuel storage let me know.
The Wrangler and Gladiator are the only two Jeep vehicles suitable for a bug-out scenario, as they are designed for off-road use and can be modified from their stock builds for extreme-use situations. The Wrangler would be preferable due to part availability for customization, maintenance, and fixes.
I installed the OEM tow hooks on my 2015 High Altitude Patriot; this required replacing the lower front fascia with one that had holes for the tow hooks. In the back, there's a d-ring shackle receiver mated to a Class III hitch.
Inside, there's a pair of entrenching tools, a pick mattock, tow strap, spare fuses, a 12V inflator, and low-profile tire chains.
Reactions: revdej
