In case anyone else searches: The lines I asked about are not available on rockauto. There are a total of six (6) lines. 2 from the master cylinder to the ABS module. One out for each wheel, the front two going to the wheels, and the rear two going to a junction block. The part I bought for ~$80 included the 2 from the master cylinder to the abs module, and the two from the abs module to the rear wheel junction block. I got lucky, as those are the ones i needed. The description and the dealership parts personnel did NOT tell me it wasn't all six lines.
The ones available on rockauto are the two from the abs module to the front wheels, sold individually for as little as $12 or $13 each side.
The lack of space is what's causing the problem in the first place. So no room for a tool. I actually just wound up buying the one piece part from the dealership. The junkyard didn't have any that looked better than mine, and the rock auto ones turned out to be the wrong parts.
The problem I had was that almost all of the nuts had fused/corroded to the lines themselves, allowing no spinning. I was torquing the whole line just to loosen the nut. This was definitely a case where spending the $80 saved me hours of frustration. I could just cut everything, making it easy to get the nuts out of the abs module etc., and it was easier to remove them from the car that way too.
