Has anyone had any experience with changing,checking,or filling the trans on one of these new transmissions???? Thank you!! Dave!!!
Here's alittle update on my question! Since no one here seemed to have any input on this new six speed transaxle system,I did some more research on it and this is what I learned.Has anyone had any experience with changing,checking,or filling the trans on one of these new transmissions???? Thank you!! Dave!!!
Since I've had this tool for a couple months now,I don't remember just where I bought it,but it was on line.When and if I can find it again,I'll post it for ya,fair enough??? I did post the part number in my post about the job.So try punchin that number in on line and see where it takes ya.I think that's how I found mine.And I think you'll find the price for this tool is all over the place!!But as long as it's the number I posted,you'll be good to go.:smiley_thumbs_up::smiley_thumbs_up: Dave!!Do you have a link for that part? I tried mopar, ebay, rock auto, amazon, google...nothing for that part number. I refuse to go to the stealership after they tried charging me $10+ shipping for two $0.20 cent bolts.
I just found it on line AND for 24 bucks.[I got screwed,I paid 35 bucks for mine]Go to Google and punch in Essential tool and service equipment and the tool number CY10323A.that should bring ya right to it. OK??? :smiley_thumbs_up::smiley_thumbs_upHere's alittle update on my question! Since no one here seemed to have any input on this new six speed transaxle system,I did some more research on it and this is what I learned.
First: This unit is NOT A CVT,it is a six speed transaxle.It uses ATF+4,which is synthethic trans oil.It doesn't have to be Chrysler specific,as long as it's ATF+4.
Second: The motor has to be up to operating temperature,at idle,and in park when checking the level.And with the E brake should be on for safety reasons
Third:You'll need a tool [Mopar part#CY10323A or equivilent which cost around 35 bucks,but well worth it] which is kinda like a dip stick,but round and heavier in construction with numbers,which are in 10MM increments,starting with 10 at the bottom and running up to 130 at the top.The tool itself is 6 1/2 inches long with a heavy round knob on the top which just sets on top of a fill hole [the fill hole plug uses a 15/16 socket with a long extension to break it free, then unscrewing it with your fingers and do NOT over tighten it when you put it back in place]. The plug for the fill/check point is located on the driver's side of the vehicle at the back left side of the motor and on the top of the transaxle.It is accessed from the front of the vehicle.
Fourth:With the engine idling and up to operating temp,the level should be around the 25MM mark,or approximately 1 inch from the bottom of the tool/dip stick.Hence with the motor off,the level should be approximately 1 inch above that 25MM mark on the stick.
Fifth: You'll need a long funnel with a tapered end to fit into that fill hole so as NOT to make a mess,pouring the ATF into the trans instead of all over it and or on the floor.lol
My trans was down alittle over 2 qts. which is a lot [I can't believe the trans wasn't damaged] but now shifts up and down a lot better.In my research,I read about a couple guys losing the trans due to over heating.Gee!! I wonder why??I guess the stealer didn't get the memo about checking the level.
And last buy not least,the stealership I bought this vehicle from will hear about this and I may even write a nasty gram to Chrysler about it.Ya see,when any new vehicle is delivered,it's supposed to get an inservice inspection,one of those things inspected being the oil and water levels because during transport,the factory leaves the levels low so they don't drip onto the vehicle below them on the car carrier used to deliver em to the dealerships.Apparently,and again,I guess most stealerships did NOT get that memo.GRRRRRRRRRRRRR!!! Dave!!!
This is how I feel about the CVT...No reason to have that tranny in a Patriot anyways, lol.
- I have better luck Googling the OEM part number 10323A without the "CY":
https://mopar.snapon.com/item-detail.aspx?itemid=5240017&type=tools ....plus many other sources.
- The correct fluid for these trannies is ATF SP-4, NOT ATF+4.
But, there is evidence that the ATF SP-4 has been superceded by ATF SP-4 M
https://www.google.com/url?sa=t&rct...dXgZwJEUJENXb4Ghu2mSinv52%2FQ%3D&usg=AFQjCNHBx_9-iRFC1FmHfi9YujMRan6LbQ&cad=rja
- Finally, you state that the fluid level should read 25 mm at "operating temperature".
Here's the fluid level table from the factory service manual:
TEMP°C(F) MIN LEVEL NOMINAL LEVEL MAX LEVEL
50° (122f) ... 21 mm... 26 mm...... 31.5 mm
55°(131F).... 23 mm.... 27.5 mm... 33 mm
60°(140F).... 25 mm.... 30 mm..... 34 mm
65°(149F).... 27 mm.... 31 mm..... 35.5 mm
70°(158F).... 28.5 mm.. 33 mm.... 36.5 mm
75°(167F).... 30 mm.... 35 mm.... 38 mm
80°(176F)... 31.5 mm... 36 mm.... 39 mm
85°(185F)... 32.5 mm... 37 mm.... 40 mm
90°(194F)... 34 mm..... 38 mm.... 41.5 mm
Besides the drain plug, there are two other ports on the the tranny, one for the dipstick level check and the other for filling. It's important to not mix the two up. The vehicle should be level during the measurement.
Here's a pic of the OEM dipstick:
Correction!! After just rechecking my OM this morning,it clearly states to use CVTF+4 in the CVT units, and SP-IV ,or equivilent [Mopar ATF-4, stamped right on the container which I bought directly from Chrysler] in the six speed auto stick units.So I don't know what to tell ya.I'm only goin by what I read in the OM and what Chrysler sold me!!![]()
or an auto stick like the Patriot has,it is NOT a CVTI originally bought a container of that CVTF+4 shown above [80 bucks, ouch] for the CVT unit which is what I thought was in the wife's new car cause that's what the salesmen told us when we bought it.But after rereading the OM,I then realized that her car had the six speed auto stick.[if a vehicle has paddles on the steering wheel and or an auto stick like the Patriot has,it is NOT a CVT unit which I have now learned.DUH!!! Hence I bought a container of the ATF+4 [also shown above] and used that.And my trans wasn't just low, I couldn't get ANY READING "PERIOD" on the stick,hot or cold.It actually took 3 qts to get a reading on the tool.Anyways,it now shifts a lot better.But had the STEALERSHIP done the inservice like they're supposed to do,this would NOT have happened. But I have learned somethin new and i thank you.:smiley_thumbs_up: Dave!!!
I'm still a bit confused. You returned the wrong CVTF+4 fluid and replaced it with the WRONG ATF+4 ?????I originally bought a container of that CVTF+4 shown above [80 bucks, ouch] for the CVT unit which is what I thought was in the wife's new car cause that's what the salesmen told us when we bought it.But after rereading the OM,I then realized that her car had the six speed auto stick.[if a vehicle has paddles on the steering wheel and or an auto stick like the Patriot has,it is NOT a CVT unit which I have now learned.DUH!!! Hence I bought a container of the ATF+4 [also shown above] and used that.And my trans wasn't just low, I couldn't get ANY READING "PERIOD" on the stick,hot or cold.It actually took 3 qts to get a reading on the tool.Anyways,it now shifts a lot better.But had the STEALERSHIP done the inservice like they're supposed to do,this would NOT have happened. But I have learned somethin new and i thank you.:smiley_thumbs_up: Dave!!!
