PROBLEM SOLVED - IT WAS A FUSE NOT PUSHED IN!
hi all-
we just picked up an 08 patriot and noticed an odd issue with the radio/keyless.
1. sometimes, the radio settings will be lost after the car sits for a short time. when turning on the car, the radio will default back to OFF, clock time wrong (was set right), and tuner on AM (it was previously FM).
2. we've noticed once a message on the instrument panel that said "no fuse" or something like that when the radio settings were lost
3. after locking the doors with the keyless, it will sometimes not unlock with the keyless (have to unlock manually, no buttons function on keyless).
4. sometimes, after driving and taking the key out of the ignition, the car will beep as if the key was still in the ignition when opening the door (lights are off). at this time, the keyless will not LOCK the doors (doors need to be locked manually, no buttons function on keyless)
other then that......... its a great car. anyone have any ideas? i'd rather skip the dealer again if i can...
thanks!
hi all-
thanks!
