I was at the junk yard last week and I picked up an arm rest from an XJ CHerokee. It has 2 bumps along the bottom that are just wider than the Patriot Arm rest. I used one screw through the center to hold it on. The screw comes through the top layer of the patriot arm rest in the finger hole for the Ipod thing.
I'm not saying this is the solution. Or that it is even a good solution. It is an easy solution. So have a look.
It makes the arm rest a little taller and a little longer which is perfect for me. It my not be for people who are taller or shorter or if you have a CVT and don't need to have the seat way up to use the clutch. Anyway, it works well for me. I need to find a way to add something the same height to the doors now.
