So I picked up a new trailer today, nice little 4x6 with a landscape type gate so I can drive my ATV right on and right off......checked it all over, lights worked, everything moving and working like it should. I go register it (about an hour in line) come home and check all the lights again before I put it away.
Now the right signal light doesn't work. I swapped the left and right bulbs and same result so it's not the bulbs. Driving light works, but signal light doesn't.
Is this a simple thing I can fix myself? I'm going to take the light housing off and take it apart and see if there is a wire loose or somthing else that looks pooched.
I hooked my boat trailer up to make sure it wasn't the truck wiring, and it was all good.
