Again, this is not being a jerk. Rather I am just offering you some good info. The 1st place you should look for any such info is always your vehicle's owner's manual. If it isn't in there then you start looking around. The plug info is right in the manual.
Hey NHPATRIOT,
On your last reply to me you told me your '11 manual stated to change plugs every 2 years vs. my '14 manual that states to just go by mileage.
This time the tables are turned. Unless I am blind, my 2014 manual does NOT list the part numbers for either the plugs or oil filter! Quite bizarro in my opinion. The plugs are not on the hood sticker either. I have the 2.4 engine.
If someone can direct me to these part numbers in the 2014 manual, I will eat crow.
Both the hard copy and CD simply say:
Engine Oil Filter: We recommend you use MOPAR® Engine Oil Filter or equivalent.
Spark Plugs: We recommend you use MOPAR® Spark Plugs (Gap0.043 in [1.1 mm]) :doh:
