I'm getting ready to switch from winter wheels to my Wrangler wheels. I use wheel spacers and they call for red Loctite (thread locker) on the lugnuts that mount the wheel spacer to the hub. I was wondering if you can tell me your method of using the Loctite.
When I've used it before, I dab a little on the threads on the insides of the lugnut and then install the lugnut. But, I have a feeling that this isn't the best method because it thins the Loctite out too much. I noticed when I took the wheel spacers off the last time to switch to winter rims, a few of the lugnuts were too easy to take off (others were really tight).
Should I but the Loctite on the bolt rather than the lugnut? Just wondering where you apply the Loctite to?
Thanks,
ski
Thanks,
ski
