Why is my patriot reving at 3000 rpm's at cruising speed? Help me out here.
KFCGREAT CAESARS GHOST!!!!
Wont that will kill you in gas?
You can't change the gear and final drive ratios since they are mechanical pieces, and don't relate to anything within the computer. Maybe you can change the shift ratio (shift points) by flashing the chip?So I'm curious- is there anyone from (or knows) Jeep engineering out there that might know answers to these questions- I'm sure there are lots of FDII owners that would LOVE to know:
1. Is there a reason the an FDII transmission HAS to rev high "at highway cruising speeds"? I understand the need to rev higher for off roading (which my Patriot does nicely), but shouldn't it be possible to rewrite the software to lower "highway speed" revs and help out mileage at highway cruising speeds?
2. If not, might it be a possibility to flash a FDII computer with FDI software so that it would lower the revs at highway cruising speeds?
I haven't tried this myself, but I've heard that putting the pedal halfway down and letting the CVT shift down and then putting the pedal down further works better. Also, you might have your dealer check and make sure you have the latest engine management programming.The other day I was picking up speed on a very very short on ramp. The Jeep reved all the way with the needle buried. The engine was making a very loud rev noise too. I let off the gas quick. I can't see this being too good for the drive train. I have the CVTII.
I think this is a common bug in the 2007 CVT's. Get it flashed at your dealer and you'll see an increase in the milage and better throttle response to boot.The other day I was picking up speed on a very very short on ramp. The Jeep reved all the way with the needle buried. The engine was making a very loud rev noise too. I let off the gas quick. I can't see this being too good for the drive train. I have the CVTII.
Well that seems alot better than what i get, i payed attention today and im at about 2850 for 68 mph (110 kph). I wonder why im revving so much more. Being a 5-spd it shouldn't slip or anything so having some more resistance from my roof basket and lights shouldn't matter, or am i wrong on this?The 2008 5MT 4WD Patriot I test drove did 2150 RPM at 60 mph which means about 2500 RPM at 70 mph.
On the 2008 CVT2 2WD I test drove, the RPM at 60 mph varied with whether I was on the level or going up a slight rise.
I had the dealer check to see if I needed an update at my first oil change, he said no. I think it's because I hammered the pedal because of the super short on-ramp. Going to have to watch that.I think this is a common bug in the 2007 CVT's. Get it flashed at your dealer and you'll see an increase in the milage and better throttle response to boot.
Unless your clutch is slipping under load, which we will hope is not happening, your roof basket and lights shouldn't matter.Well that seems alot better than what i get, i payed attention today and im at about 2850 for 68 mph (110 kph). I wonder why im revving so much more. Being a 5-spd it shouldn't slip or anything so having some more resistance from my roof basket and lights shouldn't matter, or am i wrong on this?
I have an 07 5 spd and at about 70mph it is around 2800 RPM to 3000 RPM as well. You would think that if the RPMs were that high they would just toss in a 6spd like in the liberty or wrangler.What are people revving at with the 5 spd? At 110 kph i am around 3000RPM too.
