Hi all, I was wondering if anyone has towed a caravan or trailer around 1500kg in weight with a 2.4 petrol Patriot & if so how did it go.
Cheers
Ross
Cheers
Ross
As you already discovered just look in your owner's manual and the car mfg will tell you what is safe to tow. :smiley_thumbs_up:So what is a safe weight for a 175 HP -285 FTLBS 6 speed manual transmission diesel Patriot to pull? Or is this governed by suspension,brakes, etc...? I'm confused!![]()
I agree. I only towed 1000lbs. Felt very weak.As
I think the Euro max capacity of a 2.4L gas Patriot at 3000lbs+ is flat out ridiculous however. NO WAY I would try that with my US 2.4L Patriot. They are nuts! I swear I could run along side my vehicle with it floored if it had that much weight behind it. 2000lbs IMO is more than generous for the 2.4L gas engine.
Same here... between 15-17 mpg pulling a 5x8 enclosed trailer at 1500 lbs, going 65-70I totally agree on the gas mileage. I was getting about 17 highway @60-65 mph
Sent from my Autoguide iPhone app
