Ciao,
Per chi è interessato questo è il Kit venduto in Italia per "rialzare" il pat .)
mes je crois que se nest pas recomander ses soi un ou lautre a cause de langle des cardentIf I understand (and it's not sure...), I can put the RRO lift kit on my Pat, and I can change the spring with bigger or higher spring from theses company ??
This has come up many times in many threads, namely under the question "Can I use STU's coils and the RRO?" I don''t know of any one that has tried it. Can it be physically done? Probably. Is it a good idea? Probably not. The axles aren't long enough and the CV joints aren't designed for those extreme angles. If you get custom half shafts and CV joints made, it might work.If I understand (and it's not sure...), I can put the RRO lift kit on my Pat, and I can change the spring with bigger or higher spring from theses company ??
OK. You answer my questionJeepr44 (Lambert too but in french) !!!This has come up many times in many threads, namely under the question "Can I use STU's coils and the RRO?" I don''t know of any one that has tried it. Can it be physically done? Probably. Is it a good idea? Probably not. The axles aren't long enough and the CV joints aren't designed for those extreme angles. If you get custom half shafts and CV joints made, it might work.
