So here is the issue. It happened 2 times today for the first time.
It is 0 degrees Celcius, raining/snowing, very slushy.
I am at a red light, as soon as tap the pedal to go, there was no response, and it stuttered and started up. So I figure it might just be my shoes, didn't push hard enough on the accelerator pedal.
Here I am at the next red light, this time I had my foot on the brake, the street light goes green and I see the RPM stuttering around 500rpm and the whole engine shook, I honestly thought I was going to stall, so I hit the gas pedal and the car shuttered again. It felt like I was in a manual. No Check Engine Light
Those are the 2 encounters I had. I tried to replicate the issue after with no luck. I am able to pedal-to-the-metal and hold at 6000rpm no problems and it picks up no problem, seems fine now.
I used fuel injector cleaner (Motormaster) about 1 month ago. I filled up today at Husky gas station which is what I normally put (87 Octane).
So I am at 80,000km and apparently the spark plugs may have never been changed as I purchased it from JEEP dealer at 62,000km and they have no record of it being changed there. I wish they told me or at least changed it before selling as a used vehicle. I purchased NGK G-POWER Spark Plugs today and will install them tommorow which will be gapped at 0.44.
The battery is fine. Did a test and it was 14.4v when the car was turned on and at 12.85v when off.
I know this is long but anyone experience this issue? What can it be?
2007, CVT, FWD, 5W20 Quaker State Full Synthethic.
Thanks,
Thanks,
