I'm asking this question because the Jeep dealer said the Patriot can do 98 percent the Jeep Wrangler can do
I would say it would be more like 60% and even then that would require FDII better tires and a few other things.I'm asking this question because the Jeep dealer said the Patriot can do 98 percent the Jeep Wrangler can do
I used my pat for hunting in northern ontario. Lots of logging roads and old washed out logging roads. The pat will get you to alot of places. However it has limitiations... water crossings.. mud.. steep inclines (cvt transmission) deep ruts..I would say it would be more like 60% and even then that would require FDII better tires and a few other things.
If you aren't looking at rock crawling and mud bogging you will do just fine don't expect miracles that's all
Most Wranglers are mall-crawlers, so this is probably accurate.I'm asking this question because the Jeep dealer said the Patriot can do 98 percent the Jeep Wrangler can do
Again, 6AT has a lower crawl ratio than an FD1 CVT. Have you wheeled a 6AT FD1?A FDI does not do this and even if it had the same BLD programming the lower "crawl ratio" doesn't give it enough torque to provide meaningful movement
Interesting as I've had my driver's side front wheel over 6 inches off the ground and I watched the BLD lock it.I"ve debated this before but there is still a difference in BLD programming between the FD1 and FDII vehicles, the bit difference is the pressure which is exerted on the wheel spinning.
You can tell when the FDII mode is active because it actually completely stops the wheels in the air from spinning and provides movement.
Actually it does bring things to the conversation. A FDII is exactly like a FDI any time its not in the FDII specific mode (which is gear shifter in L and 4x4 lock enaged)Big time quote fail there. I never said the 6AT's crawl ratio is "amazing" I brought it up after you made a comment that an FDI wouldn't have enough torque even if it did lock a wheel, because of it's crawl ratio.
That's a neat video, although it doesn't really bring anything to the conversation as it only shows what the FDII does, with no comparison to FDI. Honestly you are kind of all over the place here, first you said FDI wouldn't lock a wheel in the air, now it will just not as "aggressively". Look I never said FDI was the same as FDII, you got your panties all in a bunch because I stated that someone doesn't need FDII to do well off road. Which was you know, the point of the thread...
You are confusing "proof and facts" with "anecdotal evidence." ... (And again, no one is arguing that FDI equals FDII...)Actually it does bring things to the conversation. A FDII is exactly like a FDI any time its not in the FDII specific mode (which is gear shifter in L and 4x4 lock enaged)
I probably was in a hurry when I posted so i screwed up the quotes.
A FDI can "stop" a tire in the air stop lock whatever the phrase is, it simply doesn't transfer any meaningful amount of torque to the wheels with traction if you are on any sort of an incline.
As always I've got all the video proof in the world who this stuff works, take your FDI with 17:1 Crawl ratio and prove me wrong. Am I an ass, probably but I have proof and facts to back up what I say lets see some evidence of what you claim is true
