1 - 3 of 3 Posts
David Beck
I just cleaned interior with a light dust rag. Window worked fine when I went to the bank. My wife just called. Said all windows work. But, drivers side power window won't go up? Is this a circuit protector. Or a scissor lift bind. Wife tells me that green light is still on at window switch
Sorry no pics my wife is on the road right now.
Thanks for any and all ideas.
Maybe corroded switch????!!!
There are few thing it could be either faulty switch or wire broke in the door jam which I see a lot or motor burned up or broken window regulator. I suggest first lstening to hear if there is any noise when using the switch up or down like the motor trying to work if no noise probably switch, wire or motor if you hear the motor trying to work probably window regulator
Did it disconnect from the crank somehow? Mine usually rolls up when I rotate the crank back towards me.
1 - 3 of 3 Posts
