This is long, but I think it gives an accurate description of the system...
Jeep(R) Patriot Powertrain and Chassis Offer Best-in-class Off-road Capability, World-class Performance and Class-leading Fuel Economy
* Freedom Drive I 4x4 System Provides Confidence in All Weather Driving
Conditions
* Freedom Drive II Off-road Package With CVT2L Delivers Best-in-class
Off-road Capability
* Second-Generation Continuously Variable Transaxle (CVT2) Gives Customers
Improved Performance and Fuel Economy
* 2.4-Liter World Engine Achieves Class-Leading Fuel Efficiency of 30 Miles
Per Gallon on the Highway
AUBURN HILLS, Mich., Feb. 12 /PRNewswire/ -- The all-new 2007 Jeep(R)
Patriot sets a new standard for off-road capability in the compact sport-
utility (SUV) segment: a fun-to-drive vehicle that delivers best-in-class
Jeep 4x4 capability and class-leading fuel efficiency. The Jeep Patriot,
equipped with its standard 2.4-liter World Engine, achieves 30 miles per
gallon (mpg) on the highway -- fuel-economy numbers not often found on an
SUV.
"Jeep Patriot does for the compact SUV class what the brand icon Jeep
Wrangler does for the extreme off-road SUV class -- it provides the best
off- road capability in its class," said Larry Lyons, Vice President --
Front- wheel-drive Product Team. "Patriot gives first-time Jeep buyers a
fuel- efficient, fun-to-drive SUV with true off-road capability."
WORLD-CLASS POWERTRAIN ENGINEERING
The 2007 Jeep Patriot's powertrain delivers world-class performance,
fuel economy and refinement. Patriot features a standard 2.4-liter World
Engine with dual Variable Valve Timing (VVT), which helps optimize the
torque curve at all speeds. This World Engine produces more power, better
fuel economy and a smoother, quieter ride than engines without dual VVT.
Dual VVT is a technology typically not available on vehicles sold in the
United States in the Patriot's price class. Performance objectives are
targeted to match the best in the segment. The 2.4-liter engine provides
172 horsepower (128 kW) and 165 lb.-ft. (222 N*m) of torque and delivers
class-leading fuel-economy of 26 mpg in the city and 30 on the highway. A
2.0-liter four-cylinder World Engine also is available on front-wheel-drive
Jeep Patriot Sport models and achieves 26 miles per gallon in the city and
30 mpg on the highway.
Jeep Patriot features a standard five-speed manual transaxle and an
available Continuously Variable Transaxle (CVT2). CVT2 is a
second-generation CVT that Chrysler Group engineers calibrated for pleasing
engine response and precise ratio control. CVT2 contributes to a fuel
economy improvement of 6-8 percent compared with a traditional four-speed
automatic transaxle. Patriot also is the first Jeep vehicle to offer a CVT2
with integral low-ratio (CVT2L). The CVT2L's effective first gear in low
ratio is 19:1, which provides the torque necessary for crawling over
moderate rocks and logs and other off- road events.
NEW TECHNOLOGY CREATES JEEP 4X4 CAPABILITY
An electronically controlled coupling (ECC), which is attached to the
Patriot's rear differential, is the heart of Jeep Patriot's Freedom Drive I
and Freedom Drive II Off-road Package four-wheel-drive systems. Patriot's
ECC system is easier to calibrate, more flexible, more precise and lighter
than viscous-coupling or gerotor systems.
The ECC transmits torque to the Patriot's rear wheels through a
two-stage clutch system. An electromagnet powered by current from the
electronic control module operates a low-torque clutch. A cam-and-ball
mechanism amplifies the force of the low-torque clutch, applying the main
clutch that transmits torque to the rear wheels. The control module
calculates vehicle speed, turning radius and wheel slip and transfers
torque based on these conditions. The unit seamlessly interacts with the
Electronic Stability Program (ESP), Anti-lock Brakes (ABS) and Brake
Traction Control systems to ensure torque is transferred as needed,
providing better handling and traction characteristics.
Unlike other on-demand four-wheel-drive systems that rely on pumps or
viscous fluids to transfer torque, the Jeep Patriot's four-wheel-drive
system requires no front-to-rear slippage for activation. Patriot's
state-of-the-art electronic four-wheel-drive system anticipates the need
for added traction and responds to wheel slippage by automatically
transferring power to the rear wheels. The system contributes to Patriot's
excellent fuel economy by operating only when needed, minimizing
power-robbing friction and inertia.
MOST CAPABLE VEHICLE IN ITS CLASS
Jeep Patriot is available in three drivetrain configurations: the
standard front-wheel-drive system, which provides excellent ride and
handling combined with best-in-class fuel efficiency, the Freedom Drive I
4x4 system and the Freedom Drive II Off-road Package.
Freedom Drive I is an available full-time, active four-wheel-drive
system with Lock mode designed to give drivers year-round assurance for the
ability to handle rough weather and low-traction conditions. This active
four-wheel- drive system is recommended for daily use, including slick
conditions that come with rain and light snow. Freedom Drive I features a
lockable center coupling, giving drivers the ability to put the Jeep
Patriot in four-wheel- drive Lock mode to handle deep snow, sand and other
low-traction surfaces.
To activate the Jeep Patriot's Freedom Drive I Lock mode, the driver
pulls up on the chrome T-handle. This lock mode ensures that the ECC sends
the maximum amount of torque to the rear axle (up to 60 percent) for
improved traction.
The Freedom Drive II Off-road Package is an available four-wheel-drive
system that makes the Jeep Patriot a Trail Rated 4x4, creating the most
capable vehicle in the crowded compact SUV class. The Freedom Drive II Off-
road Package includes CVT2L, 17-inch all-terrain OWL tires and aluminum
wheels, a full-size spare tire, skid plates, tow hooks, fog lamps and
manual seat height adjuster.
The Jeep Patriot's Freedom Drive II Off-road Package is available on
both Sport and Limited models. This all-new Jeep technology includes the
CVT2L's best-in-class 19:1 low ratio, which is ideal for crawling over
obstacles. Off- road Brake Traction Control maintains forward movement
during heavy articulation or on split-friction surfaces where one wheel
loses traction. Hill-descent Control modulates brake hydraulic pressure
without driver intervention, providing downhill assistance at a safe and
controlled rate of speed. Brake lock differentials improve the Patriot's
mobility by applying brake force to the driven wheel that is spinning
faster than the mate on the same axle. This provides an equal amount of
torque for each wheel, thereby providing torque to the wheel with the most
traction. This helps when crawling over obstacles, during heavy
articulation activity, or when the driver encounters split-friction
surfaces or off-road driving conditions.
Trail Rated Jeep Patriot models also include a heavy-duty cooling
module, a full-size spare tire, skid plates (that protect critical
components like the engine, transaxle or fuel tank during off-road
driving), and tow hooks designed to get even the best off-roaders out of a
tight spot. Standard three- mode ESP and off-road ABS also add to the
Patriot's inherent off-road capability.
Drivers can select four-wheel Lock mode on Jeep Patriots with the
Freedom Drive I and the Freedom Drive II Off-road Package by pulling up
once on the T- shaped off-road handle in the center console. Once the
off-road handle is pulled, an amber "off-road" message in the cluster
lights up to confirm the system is on.
The Patriot responds rapidly to aggressive throttle input and delivers
better traction performance for off-road maneuvers than in the normal mode.
At speeds less than 10 mph, the maximum amount of torque is sent to the
rear axle, which effectively locks the front and rear axles together at a
50/50 torque split for optimum traction performance. At speeds less than 25
mph, the calibration for the ECC is more aggressive. At speeds above 25
mph, the coupling delivers the same amount of torque to the rear axle as in
the normal mode.
When in Off-road Mode with the 4WD Lock engaged and the shifter in the
"L" or low ratio position, the following conditions are engaged
automatically for optimal capability and performance on Jeep Patriot Trail
Rated models equipped with the Freedom Drive II Off-road Package:
* CVT2L provides an overall first gear ratio of 19:1 for crawling over
large obstacles until the vehicle approaches a speed of 10 mph or more,
when it ratios up to maintain speed
* Engine/throttle calibration is optimized for off-road driving
* Off-road ABS calibration is activated (as on non-Trail Rated vehicles)
* Traction Control reverts to brake lock differentials to help maintain
forward mobility during heavy articulation or on split-friction surfaces
when one wheel loses traction
* Hill-descent Control, a first for Jeep, modulates the brake hydraulic
pressure without driver intervention to provide downhill assistance at a
safe and controlled rate of speed. This feature uses grade-sensing logic
to determine if the vehicle is descending a hill or traveling on level
ground
* A green icon showing a vehicle descending a hill appears in the cluster
when the Off-road Mode is activated and CVT2L is in Low or Reverse
ACHIEVING TRAIL RATED STATUS
Jeep Patriot Trail Rated models are designed and tested to perform in a
variety of off-road conditions defined by five key consumer-oriented
performance categories. These include traction, ground clearance,
articulation, maneuverability and water fording, as well as measurements
that demonstrate the engine and transmission continue to self-lubricate,
while the vehicle is traveling up a side slope or on a fore/aft grade, for
consistent performance and capability. The testing for these performance
criteria is performed through a combination of physical testing and virtual
modeling.
The Trail Rated Jeep Patriot sits 1 inch higher than non-Trail Rated
versions and meets Jeep off-road capability requirements for traction,
water fording, articulation, maneuverability and ground clearance. Jeep
Patriot features standard 16-inch styled steel wheels and all-season tires.
Available 17-inch wheels and OWL tires contribute to the Trail Rated
Patriot's 9 inches of ground clearance, 29.6-degree approach angle,
34.2-degree departure angle and 23.3-degree breakover angle. Trail Rated
Jeep Patriot models also have additional body sealing and high-mounted
drivetrain vents to support 19-inch water fording capability. The Jeep
Patriot's body and chassis were developed and tested over numerous rugged
off-road terrains to meet the requirements of the enthusiast Jeep customer.
The Trail Rated badge communicates to the customer that Jeep Patriot 4x4
with the Freedom Drive II Off-road Package delivers authentic 4x4
capability.
