1 - 8 of 8 Posts
csuthrower04
Hey I know this is a foolish question but is there a spring out there with similar specs to the stu's coil for 2012+ models? I know that first gen riots can can use moog springs to lift up to the newer patriot height, but it would be great if I could get an extra inch or so with a less expensive domestic spring on my 2012.
You can also buy king springs. They are in oz as well and manufacture STU's. What you get from them isn't as heavy duty as STU's coils but still give 30mm lift. KJFR-37 (front) and KJRR-38 (rear)
What's the price on King springs?
Edit**
They are WAY cheaper.
http://www.ebay.com/itm/JEEP-PATRIOT-REAR-30mm-RAISED-COIL-KING-SPRINGS-/150739815046
Double Edit* That's just rear, not as cheap.
Triple Edit*
Here's front and rear:
http://www.ebay.com/itm/King-Springs-Front-Rear-Raised-Coil-2007-Jeep-Patriot-MK74-KJFR-37-KJRR-38-/181903469583?hash=item2a5a4aac0f:g:93EAAOSwPgxVNKdu&vxp=mtr
I wonder if you could do just the front on a 14 and level it... (Might be a touch too much lift.)
Edit**
Triple Edit*
That's an interesting find. So they will lift it, but aren't as heavy duty as Stu's?
I assume then that Stu has a custom order through Kings with different specs?
1 - 8 of 8 Posts
