141 - 160 of 268 Posts
Discussion starter · #146 ·
https://www.youtube.com/watch?v=-2J6fsLuPg4
Soooo. Yea Battery keeps dying for different reasons. Lately I've had to jump it every time I go to use it.
This video was taken with the jumpers on voltage sits at 14 all gauges work. After it cranks like that I have to re disengage the security system between starts.
I first got it started today it started on its own with no key in right when I hooked up the jumpers even with the alarm going off. It was doing this a few days ago as well..
Thinking first and foremost the battery is shot just wanted to make sure before I buy a new one. What group size should I get?
So my name is Chris and I have a built 91 xj as well! Have to post some picks when I get to my pc! That stupid group 51 battery goes every 2 years in AZ. I've got xj buddies that run group 34 batteries if you search a bit on the xj forums
Discussion starter · #149 ·
Yea im pretty sure it'd the battery because I've killed it 10+ times since I bought it, and the po did aswell somthing with the NSS he said. Gonna clean that on Friday.
I ordered new cables because those need to go the corrosion on them is horrible and picked up a starter too since it's most likely on it's way out due to the length it had the valve cover leak.
On standby with work this weekend so I can't go anywhere.... Perfect time to do all of this.
Discussion starter · #151 ·
I should every day I work on the thing the list grows more then it shrinks. I knew the eletrical work needed to be done just didn't expect it to be so sudden.
I might work on the list now slow 13 hour shift.
Also joined a club recently and they are super helpful when it comes to helping you do harder reipairs. So I should be getting some of the harder joba done on the coming months. Found a few real bad rust spots in the floor/wheel wells that gotta be fixed at some point they where pretty hidden. Was not expecting it due to the little rust on the frame rails.
Discussion starter · #152 ·
Sooo have not updated on a while
Got new tires and rims also put in a new battery, cables and starter. Jeep starts up perfectly now however the battery won't charge now... What cable runs from the batteryvro the alt I wanna see if it's connected right because that may be my issue.
You can run an extra wire from alternator to the battery positive, two wires better than one. I run two wires on my Jeep Comanche high output alternator.
Discussion starter · #159 ·
I added that ground to the bracket about the radiator a while ago worked well before I did all the new battery wires.
When I tested the alt I kept getting diffrent numbers it was jumping around every second between 12 and 19 and At times it said 1-.--.
Battery reads 9 atm with engine running and no jumpers but the voltage is running downward real fast.
I too think it's a wiring issue seeing I put in New ones I could of screwed up somewhere. I am just having difficulty finding where the wires run from the alt to the battery.
also I have no power to my wipers or radio..
http://m.imgur.com/mAI2gmq
Could this be a cause of any of it? New connector only had 1 post i have power though the top bolt as well though.
