CVT Article said:
"When the low-range mode is selected via a switch, a controller determines whether the vehicle is traveling at an acceptable rate of speed (the system can only be activated at speeds below 25 mph) and then engages a coupling mechanism, via specially developed software programming, to engage the secondary drive wheel while the CVT moves into a higher final drive ratio of up to 19:1"
[quote heckler]too many mis-information opinions instead of facts...[/QUOTE]
Irony. Just picking on you, heckler!
The whole article sounds more like marketing and opinion than fact. In the context of the article, pulling the 4x4 T-handle routes power to the rear axle. That's the only "secondary drive wheel" available on MKs and it has nothing to do with FDII specifically. And " which is more than enough to traverse just about any dusty trail or rough terrain" is clearly opinion.
To follow Hitzy:
How they calculate the top gear ratio:
Transmission - 5th gear ratio (or highest on CVT) x axle ratio = final drive ratio
CVT2L w O/R Crawl Ratio: 0.394 x 8.135 = 2.81
T-355 5-speed: 0.72 (or 0.81 for '07/'08 4x4) x 4.12 = 2.97 (3.34 4x4)
CVT: 0.394 x 6.12 = 2.41
So, what the "Low Range Gear" that the FDII gives in improved crawl ratio, it takes away from the top gear. So, CVT2 vs. CVT2L at 70mph will have the engine turning 2100rpm vs. 2700rpm in the top gear ratio.
The article does clearly state "without a two-speed transfer case."
