I went in for a CEL and walked out with a new Crankshaft Sensor and new struts (rear only). I'm having trouble making sense of the bill and can't help but think I got taken for a ride. What do you think?
think about it , why would you need an alignment if only the rear shocks [struts] were replaced. I think you misunderstood what was said because you we're in shock with the hammer job you got... I hate places like this.
What exactly did they do wrong (assuming the struts were in fact bad)? They charged 1 hour or so per strut and that is right on. The prices for the struts are about right from a shop. Pretty much every shop charges for shop supplies....60.00 bucks for shop supplies , dam , give me a break , sorry about your misfortunate situation. it's places like this that , well , you know..... screw people and give good shops a bad name.
Agreed! The only exception I can think of is solvents used to clean stuff and its disposal. A couple of squirts with an oil can or a dab of greased wiped on should be just overhead.not where i'm from. shop supplies are part of doing business. their is no doubt the price is way to high. I'm not stupid, I know garage's have to make money. they made a lot on the parts to cover supplies for sure...
If I read that right, they are charging $125/ hour for labor. That is A LOT most places around here charge 75-90, and even the dealers are around $120...
Shocks/struts can be done for about 70 bucks a corner if you buy your parts from auto zone. and take about an hour a corner for an amateur with basic tools.
There's this. Also, I live in the city and don't have a garage where I can do the work or store the tools needed.Those of us less mechanically inclined or versed need to pay someone to do the more complicated jobs for us.
I checked last night and it looks like the front and rear were replaced. I must have misunderstood. I feel a lot better about the price knowing that all 4 were done.think about it , why would you need an alignment if only the rear shocks [struts] were replaced.
I am at peace with this now. I originally thought I was getting rear only and was confused about all the parts and labor charged. The riot rides better than ever now, so I'm over it!If all is repaired and Patriot runs and drives good then chalk it up as experience. Do not beat yourself up over it as it's a done deal.![]()
City prices... Everything in my neighborhood is expensive. Next time I'll be taking it out to the suburbs to find a better deal. I definitely paid the convenience price for this one.I second this. Even the most expensive shop around here only charges $88 an hour. Even with limited knowledge I've replaced springs, removed struts, installed coilovers, installed camber arms all within reasonable time periods. I have never worked on cars other than my patriot, and it's pretty straight forward if you have a socket set, and a jack.
Franchised Chain Store, it was a Tuffy.OP,
what kind of shop did you go to? was it a local mechanic or some chain store?
