My Patriot is a 2007 with the 2.0 CRD 4WD with the Volkswagen PD engine and Aisin BG6 6 Speed Gearbox
I think I am going to need to get my clutch replaced and the dual mass flywheel. I have phoned the two nearest Jeep dealers, one quoted £767 and the other £952 :wow:
Then I phoned and independent clutch specialist and got the quote to £740, they were the most helpful and explained that some companies juts quote for the clutch then add the flywheel on once your car is in pieces. Apparently I also will need a concentric slave cylinder as well.
Looking online I can get all the parts, a Luk Clutch Kit and Slave cylinder and Sachs DMF for around £430. I have done quote a bit of mechanical work over the years but never a clutch and wondered if anybody has done it on here and if so what should I be looking out for or any tips and tricks.
Thank you for any help you can give
