7861 - 7880 of 7891 Posts
Found this on another car enthusiast forum, and thought it would be fun to see here.
Note: If you're looking for somewhere to tell about your entire project plans, this isn't it.
Post just a little something about what you did today. Whether it's messing with your sound system, changed your oil, or finally finished up a big part of the project that you've been working on, or just anything and everything.
Ok just replaced the from struts matching the new back struts with monroe gas magic/ correctly in the jeep are rear LH-RH upper and lower control arms (moogs) with 2 trailing arm bushings (ones replaced EVERYTHING) FOR THE SUSPENSION is done
Rick
Damage used simple am/fm cd sat radio took a **** / looking for another
Rick
Rick
Damn used simple am/fm cd sat radio took a **** / looking for another
Rick
Rick
Damn used simple am/fm cd sat radio took a chit / looking for another
Rick
Mr_et And Carlos, Got-r-done! Thanks for the recommendation guys. Used the Vgate interface which should come in handy for our other vehicles as well with whatever app it was they recommended. Gonna be nice pulling up to stores and NOT seeing headlights glaring back from their windows!
Low tire light came on, so i fired up my compressor. Went to get my aluminum valve stem caps off. low and behold the people at Valvoline, who serviced my Pat, cross thread them on the stem and they were beyond stuck. Had to call a tire shop and Valvoline, both told me i was SOL. Wound up destroying my caps, but my tires are full! I did find out Valvoline uses wrenched to screw caps on......who the F uses wrenched to put on caps you screw on by hand?????
That is pretty ridiculous of them. One time the shop I go to for oil changes/tire rotations put my lug nuts on so tight that they had to cut them off the next time. Thankfully they didn't try to charge me for that.
Jeep Patriot Sport 2008 – 2.4 – Manual Transmission
The first mod is done – I made footwell lights from the old BMW licence plate lights :)
I took power under from A-pillar (yellow-white wire). When you open the door the all interior lights are on – including footwell lights. Also dimming works great. All materials (lights, wires, couplings, tape) found from my garage.
Total costs 0,00 € (0,00 $). It tooks 45 minute. What you think?
91316
91317
Looks great! I bought some self adhesive LED strip lights for the footwells in mine and haven't gotten around to putting thim in yet, partially because I couldn't think of where to hook them up to. Now I know!
I made the mistake of buying tires from Walmart for my Patriot (I bought used and it had bald tires) it had some custom caps on it, and they stole them. I had to call them and the supervisor found them in tool box of the same guy that sold me the tires. It wasn't like I was going to keep them, but the fact that i technically bought them when I bought the Jeep, I was almost going to press charges, but decided not too.
The next mod; I installed aluminium pedals today. I ordered them from Aliexpress – quality is very good, install easy – just needs the drilling.
91324
Cleaned battery terminals, did a check on it too. 5 yr old OEM battery and it's still strong👍
Couple days late, but tool my Pat in for an oil change & tire rotation Thursday. Had them check the battery and charging system since my Monday fiasco, and everything is good. 6 year old OEM battery still going strong.
Changed Comet 500s in the roof with Hella’s FF75.
Not sure if they look better but preferred a lower profile
First picture is before, second in now
91332
91333
Patriot '09, 2,4 cvt 4wd
Was bored today. Due tot corona a few days off.
Took the front off and replaced the grill by black mesh.
Added some day running lights and sprayed the lip in grey.
Not so damn clean anymore.:cool: IMG_20200312_153830.jpg
Looking good (y) What kind of mesh you did use?
Thank you :)
