If there's a problem with the TPMS system, the light will flash for about a minute and then on continuously, and will do this every time on start up as long as the problem is still there.
If the light comes on steady (doesn't flash) it may be a bad tire pressure sensor or a dead sensor battery in one of the wheels.
If you have the EVIC, it will tell you which tire it is otherwise you may need to take it to a shop.
