2015 Latitude 4WD 2.4
I watched several videos now and no one had to put a load on. I'm going to assume its the struts.
Good evening, how did you remedy the issue? Did you find shorter links?Breaking news. I found my old struts laying around this morning. I measured from the center of the mounting hole directly to the bottom of the strut and I got 18 cm on the KYBs and have 19 cm on the OE Mopars. That one cm is about how much i have to lift it to put the bolt thru. They're either too long or too short by a cm depending on how you look at it.
It makes me wonder if my rears are off too, but I don't have the old ones. View attachment 96347
I didn't. I think people thought I was crazy. I just know I can insert the balljoint into the knuckle unless i have the links disconnected. I'll have another look when I service my front brakes in a couple days.Good evening, how did you remedy the issue? Did you find shorter links?
