1 - 3 of 3 Posts
I spliced into the wires that run an aftermarket sunroof what I spliced in works but now the sunroof don't any ideas what happened?
Discussion Starter #2
The hot is wired into fuse port 11 with a pre wired fuse 15 amp. Then they are ran into the dash via the side access panel this is where I tapped into them rather than trying to get a wire myself through the firewall... now the switch is running the lights I added and not the sunroof even though I reconnected the sunroof wires as well
Update I took splices out and redid it to how it was and its still not working... then I replaced my lighting back in and now they don't work either...
1 - 3 of 3 Posts
