1 - 13 of 13 Posts
· Registered
Smooths right out with shift to neutral. In the thread I just read a poll said over 80% of people had this problem, yet the posters were all over the place guessing at solutions. Has anyone ever found a definitive solution to this problem?
· Administrator
If you're talking about the "normal" vibration ( "normal" meaning no bad motor mounts, crank pulley, engine performance issues, etc. causing problems) that many of us feel in gear while stopped from the time our Patriot was new, no I haven't seen anything definitive. People have speculated on changes to the torque converter, changing idle speed, larger motor mounts with thicker material, etc. as possible improvements but I haven't seen anything confirmed.
Let us know if you find something.
· Administrator
2014 2.0 5-spd FWD
My '08 needed tranny mounts around 300,000, but the motor mounts have been fine. Likewise my Pontiac didn't need motor mounts till after 250,000. I don't think I've replaced mounts on any other vehicle I've owned (20+). Do the easy/cheap stuff first.
· Registered
2016 Jeep Patriot, 2.4L , 4x4
My '08 needed tranny mounts around 300,000, but the motor mounts have been fine. Likewise my Pontiac didn't need motor mounts till after 250,000. I don't think I've replace mounts on any other vehicle I've owned (20+). Do the easy/cheap stuff first.
Wow you are really lucky. Why do the easy and cheap stuff first if that’s not the problem?
1 - 13 of 13 Posts
