Hello all, New to the forum but long time Mopar lover, Have had my 2011 caliber and 2010 ram for several years. I recently purchased a 2012 Patriot with the automatic CVT, 4 wheel drive and 2.4 motor. After getting it home it Refuses to drive at all, forward or reverse, without severely bucking/jerking/lurching/to the point that it looks like the engine Is shaking off of the mount's, and the front wheels are bouncing up-and-down on the ground.
From other forums I have read on issues such as these, I am torn between it being a CVT issue or the throttle body. However it seems when someone has a throttle body or spark plug issue the vehicle will still run and drive just have a hesitance. My Patriot will not move unless it is from a cold start and on a level surfance and still will just idle and move, any throttle whatsoever will cause it to start bucking.
I have done the basics such as new spark plugs which are oem, And even service the transmission with a new pan filter, canister filter, and fluid. When dropping the Pan I saw no signs of transmission failure such as An unusual amount of metal shavings or burnt fluid, And the spark plugs did not change the condition. I'm hoping someone has had similar issues With the throttle body With the throttle body Being the problem, or how I can ensure that the CVT really isn't need a repair. Trying not to throw money at it And keep the wife happy.
I have a decent scanner which is not picking up any trouble codes.
