1 - 2 of 2 Posts
Patriot '09, 2,4 cvt 4wd
Yust by coincidence discovered that the chime of the safety belt stays away when you pull the belt down and hook the buckel behind the lever of the backrest.
Yes I know, the belt is there for safety but it can also be annoying for yust a little trip to the bakery around the corner.
2008 Jeep Patriot Limited. 2.4L CVT
There's actually a way to disable that chime entirely, the instructions should be in your owners manual. I think its called 'disabling belt alert'. It was posted for a newer model here but I'm sure its the same Disable Seatbelt Alarm posting....
I usually always wear my belt but when doing some low-speed offroading it is nice not to have it scratching at your shoulder!
1 - 2 of 2 Posts
