Hello!
Will someone help me solve why my right turn signal is blinking fast like the bulb is out but the bulb is fine/replaced? Also the front right DRLwon’t light up
When I engage the right blinker. It blinks two or three times normally. Then it chimes. Then it blinks fast.
solution
solution
I had the same problems with my 2008 in March. Reground the ground point G110 by stripping approximately 7 wires at the grounding point it will solved all the weird issues. It’s take about an hour to work on a confined space near the accessory belt. Good luck!!!
