I have a 2014 Jeep Patriot Sport with power windows. The rear windows do not always roll up/down when using the front driver-side switch cluster. The seem to go down more often than up but neither is dependable. They work as expected using the switches on each rear door.
I removed the driver-side door bolster today in attempts to troubleshoot the switches but was unable to locate a wiring diagram for it so I didn't get too far. I did determine there is a sound being made in both rear doors like something electrical is being engaged when the switch is pressed or lifted. So, it appears it's trying to work.
I'm not sure what is unique about the front compared to the rear mechanisms and how one would work but not the other and was hoping I might be able to get some insight as to what the problem, and perhaps the faulty part, might be before I remove all the door paneling.
Any idea? Thanks!
Any idea? Thanks!
