Over the weekend I had a chance to check some stuff out. I jacked up the rear wheels and tried to wiggle them to see if there was any play anywhere, nothing. Just a very slight bit in the upper control arm on the driver side. Nothing side to side. Next back on the ground I took a long straight bar and checked the wheel alignment, rear to front. I did this my holding it across the 3 and 9 o’clock on the rear wheel and up to the front wheel. The passenger side ran straight to the front wheel. Perfectly across the rear tire and front. Next , the driver side. Same technique, that side was about an inch out from the front wheel.
I am wondering if the driver side out of alignment is pulling on the passenger side wheel and causing the wavy cupping that is happening on the inner side of that tire.
also. I’m am trying to figure out the stock clearance from my 17” rim to the edge of the fender. I’m getting 9 1/2”. I want to see if my strut springs are going. I hopped on the bumper and everything reacted normally. Everything feels solid. Driving down the road it holds straight, no banging or noises on rough roads.
other thenwhat seems like too much negative camber and the tire wear on the inner sides. Everything seems ok.
I also took some other measurements. Ground to fuel tank strap 10.25”
Ground to outer edge of rear fender 31.75”
17” rim to outer edge rear fender 9.75”
Top of tire tread out to fender outer edge. 6”
